Temperature Effect on Fracture Toughness of PMMA (Perspex)
  • Thread starter Thread starter mikex24
    Temperature
The discussion focuses on the effect of temperature on the fracture toughness of PMMA (Perspex), specifically examining how varying temperatures (193.15 K and 373.15 K) influence the material's behavior during fracture toughness testing. Participants explore theoretical implications, experimental observations, and the concept of glass transition temperature (Tg).
  • One participant suggests that at 193 K, PMMA will be brittle, leading to easy cracking, while at 373 K, it will be ductile and may extend like rubber.
  • Another participant mentions a previous fracture toughness test yielding a K1c value of 1.6 MPa.sqrt(m) and questions how this value would change at the specified temperatures.
  • A participant highlights the importance of the glass transition temperature (Tg) in understanding the material's behavior, noting that Tg for PMMA is around 373.15 K.
  • Discussion includes the concept of brittle-ductile transition, indicating that below a certain temperature, PMMA may fail in a brittle manner, while above it, failure may be ductile.
  • One participant states that fracture toughness generally improves with increasing temperature for PMMA within a specific range, but decreases after a certain point.
  • Another participant explains that all polymer materials have a Tg, where thermal energy allows for breaking secondary bonds, affecting the applicability of fracture toughness concepts.
Participants express varying views on the effects of temperature on fracture toughness, particularly regarding the behavior of PMMA at different temperatures. There is no consensus on the exact implications of Tg or the specific changes in K1c values across the discussed temperature range.
Participants reference the brittle-ductile transition and the glass transition temperature, indicating that the discussion involves complex material behavior that may depend on specific conditions and definitions. Some assumptions about the material's properties and behavior at different temperatures remain unresolved.
This discussion may be useful for students and researchers interested in materials science, particularly those studying the mechanical properties of polymers and the effects of temperature on material behavior.
mikex24
what is the temperature effect on fracture toughness on PMMA (Perspex)?. I have done in lab yesterday a fracture toughness test to measure the K1c value of this material at room temperature. The tutor tell us to find what will be the affect of doing the same test, but with different temperatures. Same test at 193.15 kelvin and the same test at 373.15 kelvin. I am thinking that on 193 kelvin the material will be very brittle and at 373.15 will be very ductile. So at the fisrt case the material will cracked very easy and at the second case the material will not cracked but maybe extend like a rubber. I need some more information about this to make clear in my mind the effect of different temperatures for this material(PMMA-Perspex).
thank you for the reply, unfortunately i can't open that file. i have to buy it. do you have the ability to download it? thanks
We did a fracture toughness test on PMMA and the result of K1c was 1.6 MPa.sqrt (m). The question is to discuss, how the data would change if the test was conducted at -193.15 Klevin or +373.15 Kelvin?.
I think we should return this discussion to the thread for the benefit of others, and those who might also offer contributions.
I also wonder if your lab was about straddling the ductile - brittle transition. there is lots on google about this. The example picture shows nylon, not pmma but you might look around a bit.
http://www.google.co.uk/imgres?imgu...&sa=X&ei=RANfTbrDFoKp8AOKkrBa&ved=0CFIQ9QEwBw
yes, the tutor told us that the word ''GLASS TRANSITION-Tg'' will help us to answer the question. but i am not familiar with these so any help from you will help me.
I have asked others to look in as it's gone midnight here, meanwhile google
brittle - ductile transition (or the other way round)
It basically says that as a material gets colder there is a temperature below which fracture occurs by brittle failure and above which failure occurs by ductile failure.
If you plot the specific failure energy with temperature you get the characteristic S shaped curve, as shown in my link, with the transition temp at the steep near vertical part. The lower brittle energy corresponds to K1C.
... i get some idea. The tutor also asked from us to find the Tg temperature of this material. i have found it in a book that the Tg temp is 373.15. If someone can give me some idea of what the tutor would expect to see from me about the K1c and Tg temp. thank you
One should be able to save the first page of that article cited by Studiot. It actually shows the KIC value as a function of temperature.
The fracture toughness (and ductility) normally improves with increasing temperature. PMMA does over a narrow range ~360 to 380K. But it falls off after that.
PMMA also gets increased KIC as a function of decreasing temperature below 333 K.
In general, metals show a decreasing KIC with decreasing temp.
http://www.sv.vt.edu/classes/MSE2094_NoteBook/97ClassProj/exper/mcmurtry/www/matt.html
It would be interesting to see if one's own measurements are consistent.
Some universities have a subscription to Springer journals.
See if one can find - "Time-temperature dependent fracture toughness of PMMA." Journal of Materials Science 10 (8): 1381-1393.
All polymers material have a Tg . This is the temperature where the thermal eneergy is sufficient to break the secundary bondig between polimer chain. If temperature is higher than Tg then the material can "fluid", in this case Kic almost hasn`t sense because the material is little "solid" . The fracture toughness can be applied to metalic materials and you can extrapolate (with luck) to other soid materials but a polymer at temperature higher than Tg is not a solid material
  • · Replies 0 ·
11K
  • · Replies 21 ·
29K
