Determining the length of the curve (ln curve)
  • Thread starter Thread starter Riazy
    Curve Length
The discussion revolves around determining the length of a curve defined parametrically by the equations \( x = 1 + t + \frac{1}{t} \) and \( y = 3 - 2 \ln t \) for the interval \( 1 \leq t \leq 2 \). Participants are exploring the application of the arc length formula.
  • Mathematical reasoning, Problem interpretation
  • Participants discuss the use of the arc length formula and attempt to set up the integral for calculation. There is a focus on ensuring the correct formulation of the integrand, particularly regarding the square root in the expression.
The discussion is active, with participants clarifying the setup of the integral and addressing potential oversights in the formulation of the arc length expression. There is an acknowledgment of a mistake regarding the square root in the integrand.
There is a specific focus on the interval for \( t \) and the need to correctly apply the arc length formula, which may involve assumptions about the continuity and differentiability of the functions involved.
Riazy
{ x = 1 + t + 1 / t
y = 3-2 lnt
between 1<= t <= 2
Well Using the formula L = $ (from a to b) SQRT[x'(t)]^2 + [y'(t)]^2] dt
I have a problem to go further from here, could someone help solve this?
Using the formula you gave:
[tex] L=\int_{1}^{2}\left(1-\frac{1}{t^{2}}\right)^{2}+\left(-\frac{2}{t}\right)^{2}dt[/tex]
Expand and integrate...
hunt_mat:
I think you left out that the integrand in your expression for the arc length should be under a square root sign.
Your right, I have.
