Position as a function of position?
  • Thread starter Thread starter asap9993
    Function Position
The problem involves a particle's acceleration defined as a function of its position, specifically a(x) = (1.8 s^-2)x. The questions focus on determining the speed of the particle at a specific position and the time taken to travel between two positions.
  • Mixed
  • Participants discuss the integration of acceleration and velocity, with some attempting to derive a time function from the velocity. There are questions about the correctness of integration steps and the form of the equations used.
Several participants are actively engaging with the problem, offering alternative perspectives on the integration process and questioning the assumptions made in previous attempts. There is a recognition of differing interpretations of the equations involved, particularly regarding the integration constants and forms.
Participants are navigating the complexities of integrating a variable acceleration function and are addressing potential errors in the integration process. There is an ongoing examination of the assumptions related to the acceleration's dependence on position.
asap9993
Here's the problem:
Suppose the acceleration of a particle is a function of x, where a(x) = (1.8 s^-2)x.
a) If the velocity is zero when x = 1.0 m, what is the speed when x = 2.9 m?
b) How long does it take the particle to travel from x = 1.0 m to x = 2.9 m?
a = dv/dt
v = dx/dt
I managed to figure out how to do part a.
a = dv/dt
(dt/dx)a = (dv/dt)(dt/dx)
Since v = dx/dt, the above equation becomes
a(1/v) = dv/dx which becomes
a dx = v dv.
Integrating both sides gives you
v^2 = (1.8s^-2)(x^2) + C (s is seconds)
Since v = 0 when x = 1.0 meters, C = -(1.8s^-2)(m^2) (m is meters)
So the final function is v^2 = (1.8s^-2)(x^2) - (1.8s^-2)(m^2)
Plugging in x = 2.9 m, gives 3.65 m/s which is the correct answer.
I can't figure out part b. I tried using the same approach as in part a to find a "time function" :
v = dx/dt so
dt = (1/v) dx
However. when I integrate this, it doesn't give me the correct answer which is 1.29 s.
Can anyone please help me?
a dx = v dv.
Check the above integration.
You have obtained
v^2/2 = 1.8(s^2)(x - 1)
v = sqrt[2*1.8(s^2)(x - 1)]
dx/dt = sqrt[3.6(s^2)(x - 1)]
dt = dx/sqrt[3.6(s^2)(x - 1)]
Now you can find the integration.
To rl.bhat,
Shouldn't it be (x^2 - 1) instead of (x-1)? And I did the integration. It gives a natural log equation that doesn't give me the right answer
The integration adx = ax and integration of vdv = v^2/2. Now proceed.
asap9993 said:
To rl.bhat,
To asap9993
Yes, x2‒1
Also, It's v2 like you had, not v2/2.
Altering rl.bhat's solution with those changes gives:
√[1.8(s‒2)]dt = dx/√[(x2 - 1)]
Integrate to get t ≈ 1.287 s
SammyS said:
To asap9993
Yes, x2‒1
QUOTE]
Integration of xn = x(n+1)/(n+1)
In asap9993's equation, a dx = v dv, the quantity, a, is not a constant. a = kx, where k=1.8s‒1
So, upon integrating, asap9993 dropped the 2 in the denominator on both sides.
kx·dx = v·dv → kx2/2 + C/2 = v2/2
→ (1.8s‒1)x2 + C = v2 , which is what asap9993 had.
OK. That is correct.
