Derivative of Complex Function
The discussion revolves around finding the differentiability and holomorphic nature of the complex function f(z) = e^-x * e^-iy. Participants are exploring the application of the Cauchy-Riemann equations and the separation of the function into real and imaginary components.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the separation of the function into real (u) and imaginary (v) parts, with some expressing uncertainty about their approach. There are attempts to differentiate the function directly and questions about the implications of rewriting the function in different forms, such as using Euler's formula.
The discussion is active, with participants providing insights and corrections regarding the manipulation of the function and the application of algebraic rules. There is a recognition of the complexity involved in finding the derivative and the need for further clarification on the separation of components.
Participants are navigating through algebraic manipulations and the implications of negative exponents, as well as the requirements of the Cauchy-Riemann equations, which are central to determining differentiability in complex analysis.
mancini0
Hi guys, I was hoping someone can check my work finding the following complex derivative:
Find where the function is differentiable / holomorphic:
f(z) = e^-x * e^-iy
I know I must satisfy the Cauchy - Reimann equations.
I'm worried that I am not separating f(z) = e^-x * e^-iy into real and imaginary components (u,v) correctly.
In fact, I did not attempt to separate f(z) into the form f(z) = u(x,y) + v(x,y). Instead, I differentiated with
respect to f.
I found dx/ df = -e^(-x) * e^(-iy)
I found dy/ df = e^(-iy) * e^(-x)
Since dx/df = -i dy/df , the function is complex differentiable.
If that is incorrect, how would I go about seperating the original function into real and imaginary components?
Also, I noticed that f(z) = e^(-x)*e^(-iy) is equivalent to f(z) = e^-(x+iy) = f(z) = e^(-z). What can I do with this tidbit?
Use the fact that eiy = cos y + i sin y.
Then would e^-iy = -(cos y + i sin y)?
No, you can't just pull the negative sign out of the exponent. Just follow the usual rules of algebra.
Ahh, a negative exponent just gets pulled to the denominator... So e^-x * e^-iy = 1 / (e^x * e^iy)
= (e^x * e^iy)^-1
Which would lead to a complicated derivative... Would u = (e^x)^-1 , v =( e^iy)^-1 in this case? Or must I use the chain rule at this point?
[tex]f(z) = e^{-x}e^{-iy}[/tex]
[tex]f(z) = e^{-x}cos(-y)+ie^{-x}sin(-y)[/tex]
And using the common signed argument tricks for cosine and sine,
[tex]f(z) = e^{-x}cos(y)-ie^{-x}sin(y)[/tex]
Okay, thank you very much.
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 27 ·
