Ochem: H2O & HBr Reactions 2nd Semester Organic Chemistry
  • Thread starter Thread starter Acuben
The discussion focuses on the reactions of H2O and HBr with various alkyl halides and alcohols in the context of 2nd semester Organic Chemistry. It establishes that H2O does not react with 1-bromobutane due to its weak nucleophilicity, while it can lead to an SN1 reaction with 2-bromobutane, producing 2-butanol and (E)-2-butene. HBr reacts with 1-butanol and 2-butanol through SN2 mechanisms, resulting in 1-bromobutane and 2-bromobutane, respectively. Tertiary alcohols like t-butanol primarily undergo E2 reactions when treated with HBr, leading to the formation of alkenes.
  • Understanding of SN1 and SN2 reaction mechanisms
  • Knowledge of E1 and E2 elimination reactions
  • Familiarity with nucleophiles and their strength
  • Basic concepts of alkyl halides and alcohols in organic chemistry
  • Study the differences between SN1 and SN2 mechanisms in detail
  • Explore the role of nucleophilicity and basicity in organic reactions
  • Investigate the factors influencing E1 and E2 reactions
  • Review reaction mechanisms involving strong acids like HBr in organic synthesis
Organic chemistry students, educators, and anyone involved in the study of reaction mechanisms and synthesis involving alkyl halides and alcohols.
Acuben
not a HW problem, I just wanted to get this right...
(note: by primary/secondary/tertiary I mean carbon atom bonded to 1,2,3 carbons respectively
if they are actually called 1st degree/2nd degree or anything else, please correct me)
When I add H20 to primary Carbon. 1-bromobutane will it react?
How about with 2-bromobutane (2ndary carbon)
how about with t-butyl bromine (tertiary carbon)
Also...
When I add HBr to 1-butanol, 2-butanol, and t-butylol
will they react? or not react?
mostly SN1, SN2, E1, E2 reactions, or NR (no reaction
H2O + 1-bromobutane > NR
H2O is a weak nucleophile and weak base, and we have primary carbon so NR
2.
H2O + 2-bromobutane > 2-butanol + (E) 2-butene and other minor butene
H2O is a weak nucleophile and weak base, and we have secondary carbon so SN1+E1 reaction
3.
H2O + t-butyl bromine > t-butanol
Classical SN1+E1 reaction, Br will leave and deprotinate H+ , leaving OH- which then attachs to t-butoxide
4.
HBr + 1-butanol > 1-bromobutane
HBr is a strong acid, so we have Br(-1) ion, which attacks 1-butanol and forces OH group to leave
going through SN2 reaction
5.
HBr + 2-butanol > 2-bromobutane + (E) 2-butene and other minor butene
answer 1
HBr is a strong acid, so we have Br(-1) ion, which attacks 2-butanol and goes through
SN2 reaction.
or... (tell me which one is right ^^)
answer 2
HBr is a strong acid, so H+ will be added to butanol so OH group will be OH2 (+1 charge)
instead make it very good leaving group. Now Br- will attack (errr SN2?) and OH2+ will leave
6.
HBr + t-butanol > 1-methyl-2-propene
tertiary carbon so no SN2, but E2 occurs so it forms alkene
I really hate using HBr and H2O in these cases in synthesis due to their uncertainty in reaction,
nevertheless I thought I should know these in case I can't use other reagents.
Am I right? Instead of simple right or wrong, would you also add a note to each one how
strong the reaction would be?
like number 1 and 4 (2and5, and 3 and 6) can't both be right because they are opposite reaction.
as for number 5, I got the wrong in test during synthesis, but I can't understand why because I saw this reaction in my notes as well.
or could it because E2 is major in this reaction (and that notes were only explaining SN2 because E2 wasn't being covered at that time)
Handy reference table:
https://en.wikipedia.org/wiki/Nucleophilic_substitution
Most O-chem books will have something like this table. As for the reactions:
1. This is fine. Water won't react (at least in the short term).
2. I can see where you would get this from, but in reality 2-bromobutane isn't really reactive with water. If I had to say what a possible reaction would be, SN1 would be it.
3. This is fine too. In reality, in neutral water, Br- is not basic. The OH- will come from autoionization of water.
4. HBr protonates the OH group, giving an H2O+ group, which is an excellent leaving group. Then another HBr attacks the backside in an SN2 and the extra proton on the HBr is grabbed by a water molecule. One important feature here is that if you're in a strongly acidic environment (like with HBr), you aren't really ever going to see formal negative charges show up in reaction mechanisms, only positive ones. And vice versa in a strongly basic environment. If, for example, your first 3 reactions involved putting butyl bromide into NaOH, you wouldn't have reaction mechanisms with formal positive charges flying around.
5. As mentioned before, since you're in a strongly acidic environment, the HBr will protonate the OH group. From here, secondary alkyl halides tend to see competition between SN1 and SN2 mechanisms. The elimination mechanisms are more important in basic media, but here E1 might compete to some extent (especially since the product is a gas in this case: it is at least strongly entropically favored). (Sometimes eliminations are also highly enthalpically favored, e.g., sulfuric acid + ethanol at high temperatures will give the dehydration product ethylene)
6. Tertiary carbons only ever react through SN1 mechanisms. So the SN2/E2 question is irrelevant. You will probably see competition between SN1 and E1 reactions in this case, if I had to guess.
9K
