Solving 2D Collision Problems with Mass and Speed
  • Thread starter Thread starter joej
    2d Collisions
The discussion revolves around solving two-dimensional collision problems involving elastic collisions between particles of different masses and speeds. The first problem involves two billiard balls colliding at right angles, while the second problem concerns an atomic nucleus colliding with a target particle at rest.
  • Mixed
  • The original poster attempts to apply conservation of momentum to determine the final speeds and directions of the billiard balls after their collision. They express uncertainty about their conclusions and seek validation.
  • For the second problem, the original poster indicates confusion regarding the algebra involved and questions how to start applying conservation of momentum and kinetic energy principles.
  • Some participants suggest using vector components for the first problem and provide links to external resources for further understanding of collision problems.
  • Another participant mentions the general outcome of equal mass elastic collisions, noting that the resulting velocities are at right angles, except in head-on collisions.
The discussion is ongoing, with participants exploring different interpretations and approaches to the problems. Some guidance has been offered regarding the use of vector components and the principles of conservation of momentum and kinetic energy, but no consensus has been reached on the specific solutions.
Participants are grappling with algebraic expressions and the implications of mass differences in the second problem. The original poster also notes a lack of confidence due to the absence of answers in the provided key.
joej
okay I think my brain is fried cause I've never before had so many problems in one day anyways...
1) Two billard balls of equal mass move at right angles and meet at the origin of an xy coordinate system. A red one is moving upwards along the y-axis at 2m/s, and a green one is moving horizontally (to the right) along the x-axis at 3.7m/s. After the collision (elastic), the green ball is moving along the possitive y axis. What is the final direction of the red ball and what are their two speeds?
now since I use conservation of momentum I am getting that the green ball would be moving up the y-axis (90 degrees) @ 2m/s, and the red ball is moving along the x-axis (0 degrees) @ 3.7m/s. I do not have this question in the answer key but I am more then 100% sure that this should be correct, am I missing something or is it really right?
now 2nd one I don't really have a solution as it doesn't involve numbers and only algerbra and I hate algebra, so this one is where I really need some help if possible:
2) An atomic nucleus of mass m traveling with speed v collides elastically with a target particle of mass 2m(initially at rest) and is scattered @ 90 degrees.
a) At what angle does the target particle move after the collision
b) What are the final speeds of the two particles
c) What fraction of the initial KE is transferred to the target particle
now for this one I am lost as to where to even start, I'm pretty sure I should be using conservation of momentum equationsalmost like in the previous one, except that the mass is different so that cannot be canceled out, but the letters are messing with my head.
Redo the first one using vectors (x and y components).
To derive the solution from first principles is not trivial. But the result is that for equal masses, an elastic collision results in the masses moving with velocities at 90 degrees to each other (except for perfectly head-on collisions). That is all you have to know. (This is a very useful rule when playing pool. If you want to set up for the next shot you have to know the direction the cue ball will go). I think the answer is pretty obvious from that: You know the directions. You then set the speeds in order to conserve the x and y components of momentum, which is what you have concluded.
In this case, the momentum of the system is [itex]mv_0[/itex] before and after the collision. So [itex]2mv_2 cos\theta = mv_0[/itex] where [itex]\theta[/itex] is the angle of the second (larger) mass from the original direction of [itex]m_1[/itex]. Also [itex]2mv_2 sin\theta = mv_1[/itex] .
Also conservation of KE means that [itex]v_0^2 = v_1^2 + 2v_2^2[/itex].
The rest is just math.
  • · Replies 32 ·
