Confused about the definition of a limit
The discussion revolves around the definition of a limit in calculus, specifically the epsilon-delta definition. Participants explore the implications of this definition, particularly in relation to bounded functions and the behavior of epsilon values in various scenarios.
  • One participant argues that if a function f is bounded above by a constant C, then the limit L must also be less than or equal to C, suggesting that this creates a restriction on the epsilon neighborhood.
  • Another participant counters that the definition allows for any epsilon > 0 and that larger epsilons simply provide weaker conditions without restricting the definition.
  • A third participant questions the implications of using smaller epsilon values in relation to the function |xsin(1/x)|, suggesting that epsilon can be bounded below by |x|.
  • A later reply corrects the previous statement by clarifying that the condition involving |x| is a restriction on x, not on epsilon, emphasizing that epsilon is predetermined.
Participants express differing views on the implications of the epsilon-delta definition, particularly regarding the restrictions on epsilon and the behavior of functions within certain bounds. The discussion remains unresolved with multiple competing perspectives.
Participants highlight the dependence on definitions and the conditions under which the epsilon-delta definition operates, indicating that assumptions about the behavior of functions and the relationship between epsilon and x are critical to the discussion.
torquerotates
So the definition states.( For any epsilon>0, there exists a delta>0 such that 0<|x-a|<delta => |f(x)-L|<epsilon. ) is equivalent to lim f(x)=L for x->a.
Well say f<=C some constant.
(reads less than or equal to)
then L<=C But that means that the epslion neighborhood can't extend past C. f is always going to be in (L-epsilon, L+epsilon). If L+epsilon>C, then there exists x* such that f(x*)>C. This puts a restriction on the values of epsilon. But the definition states that for ANY epsilon>0. epsilon should be as great as I want it. But it isn't.
It puts no restriction on the epsilons. As you can see, if there is a delta > 0 such that |f(x)-f(y)|<epsilon when |x-y|<delta, then this delta works for all epsilons bigger than the one we have used! All we need is that the function is close enough to f(x) around x, so if we "give it more slack" to vary, it won't do any harm.
In your example it is no reason for that the epsilon neighborhood can't exceed the range of the function. If so you would e.g. immediately get in trouble with constant functions. As explained above larger epsilons only give weaker conditions.
Oh I see. But then what about smaller epsilon? Say |xsin(1/x)|<=|x|<epsilon? Can I say that even though epsilon is bounded below by |x|, since |x|<delta=epsilon, and delta>0, |x| can take on all values less than the current epsilon so we can find a epsilon smaller than the one we have but greater than |x|?
"even though epsilon is bounded below by |x|" is incorrect. |xsin(1/x)|<= |x|< epsilon puts a condition on x, not on epsilon. epsilon is "given" initially. You control values of x, not epsilon.
  • · Replies 20 ·
  • · Replies 25 ·
