How Is Power Calculated in a Simple Work-Energy Problem?
  • Thread starter Thread starter StonieJ
    Work-energy
The power calculated in the work-energy problem involving a 5N force acting on a 2 kg object for 2 seconds is definitively 12.5 W. The calculations confirm that the acceleration is 2.5 m/s², the distance traveled is 5 m, and the work done is 25 J. The formula for power, P = Work / time, yields the correct power output of 12.5 W, which is not included in the provided answer choices. The discrepancy indicates an error in the answer options rather than in the calculations.
  • Understanding of Newton's Second Law (F = ma)
  • Knowledge of kinematic equations for uniformly accelerated motion
  • Familiarity with the concepts of work and power in physics
  • Ability to perform basic algebraic calculations
  • Review the derivation of power from work in physics
  • Explore the implications of non-constant forces on power calculations
  • Study examples of work-energy problems with varying forces
  • Learn about the significance of units in physics calculations
Students studying physics, educators teaching mechanics, and anyone interested in understanding work-energy principles and power calculations.
StonieJ
A force of 5N acts on a 2 kg object that starts from rest. When the force has been acting for 2 s, the rate at which it is doing work is:
Here's how I tried to solve it.
Solve for acceleration, which I assumed was constant.
Code:
a = F/m = 5N / 2kg = 2.5 m/s/s
Then use the displacement equation to find the distance traveled.
Code:
x = xo + (vo)(t) + (1/2)(a)(t^2)
x = 0 + 0 + (1/2)(2.5 m/s/s)(2s)^2
x = 5m
Work = F * x = 5N * 5m = 25 J
Power = Work / t = 25J / 2s = 12.5 W
However, the only possible answer choices are:
a) 5W b) 10W c) 25W d) 50W e) 75W
Where am I screwing up?
[tex]P=\frac{dW}{dt}[/tex]
[tex]P=\frac{d(Fs)}{dt}[/tex]
[tex]P=F\frac{ds}{dt}[/tex]
[tex]P=F\frac{d(ut+\frac{1}{2}at^2)}{dt}[/tex]
[tex]P=F*(u+at)[/tex]
[tex]P=5*(2.5*2)[/tex]
[tex]P=25\ W[/tex]
You formula for power can't be used in this case because P is not constant for P depends on how long the force acts on the object.
You are not screwing up, your calculations are correct. The only issue is that the answer choices provided are not all correct. The correct answer should be 12.5W, which is not listed as an option. This could be a mistake or error in the question or answer choices. It is always important to double check your calculations and compare them to the given answer choices to ensure accuracy. In this case, your calculations are correct and the given answer choices are incorrect.
  • · Replies 16 ·
  • · Replies 25 ·
