| New Reply |
finding magnetic field from magnetic force / semielliptical conductor |
Share Thread | Thread Tools |
| Feb23-11, 01:22 AM | #1 |
1) A charge Q is placed in a uniform magnetic field of magnitude a that proceeds in the -z direction. Its displacement is given by r(t) = (at^2+bt, 2bt, a). a) Find v(t). c) Find the magnetic force exerted on the charge at time t=t'. d) Now the magnetic field at time t' has changed; a magnetic force vector F = (0, -ab, 4bt^2) is now exerted by the field on the charge in addition to the original magnetic force vector. If the charge has the same velocity, and y-component of B = 0, what's the additional magnetic field? 2) A semi-elliptical conductor (semimajor axis a, semiminor axis b) is centered at the origin in the xy-plane. The conductor carries a current I a CCW direction. Write the integral expression for the magnetic field vector due to the semi-elliptical conductor at the origin. 2. Relevant equations 3. The attempt at a solution 1) a) v(t) = r'(t) = (2at + 2b, 2b, 0) c) not sure about this one: F = Q * v(t') * B * sin(theta); but theta = 90 degrees because B goes in -z direction and v(t) doesn't have a z component. Therefore, F = Q * sqrt( (2at+2b)^2 + 4b^2 ) * a d) This is the one I have no idea how to solve. I don't even know how to start. Do I have to use the law of Biot and Savart to find the magnetic field? If so, how? I assume another possibility would be to find the "inverse cross product" (if such a thing exists) of the given force vector - but I was told by our professor we don't have to do that. Any hints? 2) We only have to express the integral, not solve it. This is how far I got: dB = mu0 / (4*Pi) * (I * dl) / r^2, because dl is perpendicular to the "radius" of the ellipse at any point. But the radius itself varies. How do I express that? I looked up the the equations of an ellipse in polar coordinates, so I assume I could use that. But I'd rather understand what exactly I'm doing than simply plugging in equations from the internet. Thanks. |
| Feb23-11, 08:51 AM | #2 |
1.d)biot and savart is for current distributions; why use that?
Go on with the lorentz force law. Vectorially add the magnetic forces and equate to (qv)X(B_net). You'll get 3 equations each along x,y and z directions. Solve them and get your field B. regarding 2, what is the centre of a semi-elliptical conductor? |
| Feb23-11, 11:48 AM | #3 |
Thanks for your answer, saubhik. For 1d) I assumed that's how I have to solve it, but I was specifically told not to - there must be some property that simplifies the problem.
The center of the semi-elliptical conductor is the the point midway between the two foci. |
| New Reply |
| Thread Tools | |
Similar Threads for: finding magnetic field from magnetic force / semielliptical conductor
| Magnetic field outside a conductor | Classical Physics | 1 | ||
| Dragging loop out of magnetic field (Finding Force) | Introductory Physics Homework | 5 | ||
| Finding the force of magnetic field lines | Introductory Physics Homework | 1 | ||
| magnetic force, finding angle between velocity and magnetic field | Introductory Physics Homework | 4 | ||
| Force on a conductor in a magnetic field | Introductory Physics Homework | 3 | ||
