Find a function f that has a continuous derivative
The problem involves finding a function f that has a continuous derivative on the interval (0, ∞) and passes through the point (1, 1). Additionally, the length of the curve from (1, 1) to any point (x, f(x)) is defined by a specific formula involving the natural logarithm and f(x).
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the relationship between the given arc length formula and the integral representation of arc length, considering the application of the fundamental theorem of calculus. There are attempts to derive equations and manipulate them to find f(x).
Participants are actively engaging with the problem, exploring different mathematical approaches and questioning each other's reasoning. Some guidance has been offered regarding the manipulation of equations and the application of derivatives, but there is no explicit consensus on the next steps or the final form of the function.
There are indications of confusion regarding the integration process and the treatment of constants. Participants are also questioning the necessity of the constant C in the final function.
rjs123
Find a function f that has a continuous derivative on (0, ∞) and that has both of the following properties:
i. The graph of f goes through the point (1, 1)
ii. The length L of the curve from (1, 1) to any point (x, f(x)) is given by the formula L = lnx + f(x) - 1
Recall that the arc length from (a, f(a)) to (b, f(b)) is given by the formula
So, what did you try already??
I think the fundamental theorem of calculus will be useful here... since you know the arc length, you can set it equal to the integral.
I'm not really sure where to start...but I'm assuming I pick a random integer from 1 to infinity to represent b. Since I'm given the equation for f(x)'s arclength from 1 to any point to infinity: L = lnx + f(x) - 1
...should i set it equal to the equation for finding arclength in general? I've never seen this type of problem before so I'm a little puzzled.
Well, you can do what Char limit proposed. The length from 1 to x is given by ln(x)+f(x)-1. But on the other hand, the lenth is also given by
[tex]\int_1^x{\sqrt{1+(f^\prime(x))^2}dx}[/tex]
So, setting them equal gives you
[tex]ln(x)+f(x)-1=\int_1^x{\sqrt{1+(f^\prime(x))^2}dx}[/tex]
Now derive both sides...
Let x = 3
[tex]ln(3)+f(3)-1=\int_1^3{\sqrt{1+(f^\prime(x))^2}dx}[/tex]
[tex]ln(3)+f(3)-1=\int_1^3{{1+(f^\prime(x))}dx}[/tex]
[tex]ln(3)+f(3)-1={{x+(f(x))}} from 3 to 1[/tex]
This is what I have so far...am i on the right path?
rjs123 said:
Let x = 3
I really don't know what you did there. You can't eliminate the square root like that. It is NOT true that [tex]\sqrt{a+b}=\sqrt{a}+\sqrt{b}[/tex]!
Instead, you have to take the derivative of both sides and apply the fundamental theorem of calculus...
dont you mean integral of both sides, and i thought the left side should be left alone...no? I'm stuck on integrating the right side...any help would be appreciated.
No, I really mean to take the derivative of both sides! This will make the integral disappear...
becomes this correct?
[tex]1/x+f^\prime(x)={\sqrt{1+(f^\prime(x))^2}[/tex]
Yes, good. Now square both sides and solve for f'(x). Then integrate.
next steps:
[tex](1/x+f^\prime(x))^2={1+(f^\prime(x))^2}[/tex]
[tex]1/x^2+f^\prime(x)^2={1+f^\prime(x)^2}[/tex]
I haven't had calc in a while...if solving for f'(x) wouldn't they cancel each other out here?
You squared the left side wrong.
[tex](a+b)^2 \neq a^2 + b^2[/tex]
[tex](a+b)^2 = a^2 + 2 a b + b^2[/tex]
next steps:
[tex]1/x^2+ 2f'(x)/x + f'(x)^2=1+(f^\prime(x))^2[/tex]
[tex]1/x^2+ 2f'(x)/x=1[/tex]
simple mistake...im now here
multiply by x?
Multiplying by x will help, yes. Then you need to subtract 1/x.
[tex](a+b)^2 = a^2 + 2 a b + b^2[/tex][/QUOTE]
next steps:
[tex]2f'(x) = 1 - 1/x[/tex]
[tex]f'(x) = (1 - 1/x)/2[/tex]
whats a good simplification of the right side for easier integration...[tex]f'(x) = 1/2 - 2/x[/tex]?
f(x) = 1/2x - 2lnx + C ...final answer? i'll double check this right now
There is a mistake here. After multiplying both sides by x, you should get 2f'(x) = x - 1/x. After that, I would treat them separately.
f'(x) = x/2 - 2/x
After integrating
f(x) = 1/4x^2 - 2lnx + C
is there a way to give you reputation or something for your help...i appreciate it.
I don't know if there's a way to do that, and it's not really necessary. Just thanks are good.
Although you should have integrated 1/(2x), not 2/x...
f(x) = 1/4x^2 - 1/2ln(2x) + C
is the C necessary here?
it appears
does not intersect f(x)...im guessing to set f(x) to 1...then find C...by plugging in 1 for x?
1 = 1/4(1)^2 - 1/2ln(2) + C
1 = 1/4 - 1/2ln(2)
3/4 + 1/2ln(2) = C
f(x) = 1/4x^2 - 1/2ln(2x) + 3/4 + 1/2ln(2)
  • · Replies 20 ·
