Is 1+2+3+4+...+(n-1) divisible by N (odd positive integer)?
  • Thread starter Thread starter Isaak DeMaio
    Induction Proof
The discussion revolves around proving a statement related to the sum of the first (n-1) integers and its divisibility by an odd positive integer N. Participants are exploring how to show that the sum 1 + 2 + 3 + ... + (n-1) is congruent to 0 modulo N, particularly using induction as a method of proof.
  • Exploratory, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants are discussing the use of induction to prove the statement, with some suggesting to express N as 2k + 1 for an integer k. Others are questioning how to handle the modulus and whether certain expressions are valid. There are attempts to clarify the induction steps and the base case, with some participants expressing confusion about the setup and the relationships between the variables involved.
The discussion is ongoing, with various approaches being explored. Some participants have provided insights into the induction process and the necessary steps, while others are still seeking clarity on specific points. There is no explicit consensus yet, but several productive lines of reasoning have been introduced.
Participants note that the problem has not been covered in their coursework, and there are indications of uncertainty regarding the definitions and properties of modular arithmetic. The discussion includes attempts to relate the problem to known mathematical principles and previous examples.
Isaak DeMaio
1. This is an extra credit question for me, we haven't gone over this at all.
Show by induction that if N is an odd positive integer then 1+2+3+4+...+(n-1) congruent 0 (mod n)
3. Never done a problem like this before, but I assume after the (n-1) it would be (n-1)+n congruent 0 (mod n+2)
... after the (n-1) it would be n+(n+1) congruent 0 (mod n+2)
The following may fit induction better.
Any odd integer may be expressed as 2k+1, where k is an integer. If n = 2k+1, then the next odd integer (greater than n) is given by n+2 = 2(k+1)+1 .
Then n-1 = 2k. So you need to show that 1+2+3+4+...+2k ≡ 0 (mod 2k+1 )​
So would it be:
0(mod n) + [n+(n+1)] = 0(mod n+2)
if done the way the question presents itself.
Isaak DeMaio said:
So would it be:
Yes, for the induction step.
For n odd, n>0, then n=2k+1 for some k≥0.
Show that 1+2+...+2k = k(2k+1) .
This is equivalent to showing that:
1+2+...+(n‒1) = ((n‒1)/2)(n)
How would you cancel out the mods? Or do such things to them to try and make them equivalent?
You can get rid of the modulus business by using the definition of 0 (mod n). For example, the equation
1 + 2 + 3 + ... + (n - 1) [itex]\equiv[/itex] 0 (mod n)
is the same as saying
1 + 2 + 3 + ... + (n - 1) = kn, for some integer k. (It's also given that n is an odd positive integer.)
You can do something similar for the other modulus equation.
The idea here is to use the above as a "Lemma". Proving this by induction is a natural thing to do.
Following what Mark44 said, but using the variable, m, instead of k, which was already used, you have the following
Letting m = (n‒1)/2, you then have:
1+2+...+(n‒1) = (m)(n) .
it has to be in K's
so k-1 = mk
Isaak DeMaio said:
it has to be in K's
so k-1 = mk
No, not at all, if I'm following what you're doing. What I said in my earlier post was
if 1 + 2 + 3 + ... + (n - 1) [itex]\equiv[/itex] 0 (mod n),
then 1 + 2 + 3 + ... + (n - 1) = kn for some integer k.
If your first equation is 1 + 2 + 3 + ... + (k - 1) [itex]\equiv[/itex] 0 (mod n), then the second equation is then 1 + 2 + 3 + ... + (k - 1) = mk for some integer m.
It's not true that k - 1 = mk.
i meant (k-1) i just didn't do the parent...
The parentheses aren't the issue here, k - 1 is the same as (k - 1).
Would the set up be...
(mk) + (k-1) = (m)(k-2)? Why why is it minus 1 and not plus one again?
You're skipping too many steps for me to follow easily.
Show us your induction proposition and then show is the proposition you need to prove.
I always skip those parts mostly because I don't get those parts.
would that be:
mk + [k+(k+1)] = m(k+2)?
That explains why some of your work is so hard to follow. You can't do an induction proof without showing all three steps.
This makes no sense at all. It is saying that 0 + n + n + 1 = 0; IOW, that 2n + 1 = 0. That's not going to fly.
Isaak DeMaio said:
would that be:
SammyS and I have laid out two slightly different approaches. Go back and read the posts in this thread and pick one of the ways presented, and we can go from there.
Well I don't know what you mean by "the definition of 0 mod n"
But I'll go your way I suppose.
If [itex]x \equiv 0 (\text{mod n})[/itex], that means that x is an integer multiple of n.
Ahhh yes. so could you say," K=N" in this proof? well it'd be k greater = n
As I said a few posts back - Show us your induction proposition and then show is the proposition you need to prove.
1+2+3+4+...+(n-1) = (n-1)/2 (n)
n≥1
1...1=0(mod1).
2...2=0(mod2)
3...3=0(mod3)
4...4=0(mod4)
Prove:1+2+3+4+...+(k-1)+k(k+1) = (k-1+1)/2 (k+1)
k≥1
Would that be it?
I second what Mark44 said.
Added in EDIT:
Ignore this. It was a response to a post a few back.
didnt i just do that?
The general statement:
n is a positive odd integer
Show that 1 + 2 + 3 + ... + (n - 1) [itex]\equiv[/itex] 0 (mod n)
Base case:
1 + 2 = 3 [itex]\equiv[/itex] 0 (mod 3)
This establishes the base case.
Induction step:
Let n = k
Assume that 1 + 2 + 3 + ... + (k - 1) [itex]\equiv[/itex] 0 (mod k) is true. (*)
Now let n = k + 2 (to get to the next odd number)
Show that 1 + 2 + 3 + ... + (k - 1) + k + (k + 1) [itex]\equiv[/itex] 0 (mod k + 2). Use (*) in showing this.
Note that the sum on the left starts at 1 and ends at some even number, so in the induction step, you need to add on two more numbers.
This is true, but I don't see how it is related to this problem.
Isaak DeMaio said:
n≥1
1...1=0(mod1).
2...2=0(mod2)
3...3=0(mod3)
4...4=0(mod4)
These don't make any sense. In each of the equations above, the left side apparently consists of a single number. That's not what this problem is about.
Equations that are pertinent include the following:
1 + 2 + 3 + 4 = 10 [itex]\equiv[/itex] 0 (mod 5)
1 + 2 + 3 + 4 + 5 + 6 = 21 [itex]\equiv[/itex] 0 (mod 7)
Any one of these establishes a base case, but they don't do anything for establishing the induction step.
k≥1
Would that be it?
Mark44 said:
Now let n = k + 1 (to get to the next even number)
Pardon me for butting in, but I'm sure the line I highlighted should say:
The line following that is fine.
n≥1
At Mark44;
That came from me, in post #5.
The idea here is that this can be proved by induction and that clearly: ((n-1)/2)(n) ≡ 0 (mod n)
No problem, and thanks. I edited that post to reflect the change. I was thinking about the last number in the sum, which has to be even, when I wrote that.
So I should follow this:
Show that 1 + 2 + 3 + ... + (n - 1) 0 (mod n)
Base case:
1 + 2 = 3 0 (mod 3)
Induction step:
Let n = k
Assume that 1 + 2 + 3 + ... + (k - 1) 0 (mod k) is true. (*)
Show that 1 + 2 + 3 + ... + (k - 1) + k + (k + 1) 0 (mod k + 2).
Then try and prove it to get the correct answer?
So it would be 3k=0(mod k+2)
Could you subtract the K over to get 2k=0(mod2)?
then would that be it?
  • · Replies 30 ·
