Effortlessly Integrate \frac{2mdx}{cx^2} from x to 0 | Expert Tips
The discussion focuses on the integration of the function \(\frac{2m}{cx^2}\) from \(x\) to \(0\). It highlights the issue of using the same variable for both the limits of integration and the dummy variable, which is considered bad practice. The correct form should be \(\int_x^0 \frac{2m}{ct^2} dt\), but this leads to an improper integral due to the singularity at \(t=0\). Consequently, the integral does not exist.
  • Understanding of improper integrals
  • Familiarity with variable substitution in calculus
  • Knowledge of integration techniques, specifically for rational functions
  • Basic concepts of limits in calculus
  • Study improper integrals and their convergence criteria
  • Learn about variable substitution methods in integration
  • Explore techniques for integrating rational functions
  • Review the concept of limits and their application in calculus
Students and professionals in mathematics, particularly those studying calculus, as well as educators looking to clarify integration techniques and common pitfalls.
Speags
i need to intergrate this function
[tex]\frac{2mdx}{cx^2}[/tex]
from x to 0
If you meant to write:
[tex]\int_x^{0} \frac{2m}{cx^2}dx[/tex]
Then you've got the variable of integration in the limits of integration which is ...problematic.
It is bad practice, although it is often done, to use the same letter to represent the "dummy" variable of integration and as a variable outside the integral (as in one of the limits of integration).
If you meant
[tex]\int_x^0\frac{2mdt}{ct^2}[/tex]
Then rewrite the t2 in the denominator as t-2:
[tex]\frac{2m}{c}\int_x^0t^{-2}dt[/tex]
You still have a problem- that's an improper integral which will have serious difficulties at 0! This integral does not exist.
  • · Replies 18 ·
  • · Replies 19 ·
