New Reply
Elliptic Integral
Share Thread Thread Tools
Feb25-11, 01:12 PM   #1
G01
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Elliptic Integral
Sub problem from a much larger HW problem:
From previous steps we arrive at a complete elliptic integral of the second kind:
[tex]E(k)=\int_0^{\pi/2} dx \sqrt{1+k^2\sin^2x}[/tex]
In the next part of the problem, I need to expand this integral and approximate it by truncating at the first order term. (k is large)
2. Relevant equations
[tex]E(k) = \frac{\pi}{2} \sum_{n=0}^{\infty} \left[\frac{(2n)!}{2^{2 n} (n!)^2}\right]^2 \frac{k^{2n}}{1-2 n}[/tex]
3. The attempt at a solution
I believe I should use the expansion quoted above.
Here is my question. Based of the previous steps I know that k^2 has to be large. Also, the sign of k^2 is opposite of what is is in the standard form of E(k).
So, 1. Does this expansion truncated at first order approximate the integral well if k^2 is large?
I think not. Is there another expansion, one for large k^2, that I can potentially use?
2. Can I just change the sign in the odd terms of the expansion to account for the sign change of k?
I think this should work.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Feb25-11, 01:17 PM   #2
Recognitions:
The expansion above is not valid for large [tex]k[/tex]. Simply rewrite
[tex]
E(k)=\int_0^{\pi/2} dx \sqrt{1+k^2\sin^2x} = \pm \int_0^{\pi/2} dx k \sin x\sqrt{1+\frac{1}{k^2\sin^2x}}
[/tex]
and expand this in [tex]1/k[/tex] yourself. Note that taking the square root introduces a sign ambiguity that should be chosen to give the correct sign to [tex]E(k)[/tex].
Feb25-11, 03:05 PM   #3
G01
Recognitions:
Quote by fzero View Post
[tex]
[/tex]
Hmm. This makes sense, however, it is only a good approximation when sin(x) is larger than 1/m.
However, the contributions to the integral in [0,1/m] are small, so can I fix the approximation by changing the lower bound on the integral to 1/m?
Feb25-11, 08:10 PM   #4
Recognitions:
Elliptic Integral
Quote by G01 View Post
I'd write the expansion as a power series, do the integrals and then check convergence.
Mar1-11, 01:25 PM   #5
G01
Recognitions:
Yeah you were right. The higher order terms don't necessarily converge with a lower bound of 1/m.
Checked with my prof. Looks like if you use 1/m as the lower bound and expand to first order, you get the correct result up to a multiplicative constant on the resulting ln(m) term.
I think can finish the rest of the problem now. Thanks fzero!
New Reply
Thread Tools
Similar Threads for: Elliptic Integral
Thread Forum Replies
elliptic integral Calculus 8
Elliptic integral Calculus 0
Elliptic integral Advanced Physics Homework 2
Elliptic line integral Calculus & Beyond Homework 3
Elliptic Integral Calculus 3
