Question about integration by substitution?
The discussion revolves around the use of integration by substitution, particularly in the context of integrating the function sqrt(1+x) over the interval from 0 to 8. Participants explore the conditions under which substitution is applicable and express confusion regarding the presence of the derivative in the integrand.
  • Technical explanation, Conceptual clarification, Debate/contested, Mathematical reasoning
  • One participant expresses confusion about the application of substitution in integration, questioning how the derivative exists next to the function sqrt(1+x) when substituting u=(1+x).
  • Another participant suggests a method of rewriting the integrand and indicates that the substitution u=(1+x) leads to a valid transformation of the integral.
  • A participant reiterates their confusion about the derivative's presence, suggesting that it may be implicitly equal to 1 in this case.
  • One participant points out that the variables are linearly dependent, noting that dx/du equals 1 when considering the substitution x=u-1.
Participants do not reach a consensus, as there are differing interpretations of the role of the derivative in the substitution process and the implications of the transformation.
There are unresolved questions regarding the assumptions made about the derivative's presence and the conditions under which substitution is valid in this specific integration problem.
MathWarrior
I am confused about integration in other cases, I understand that you can use substitution if the derivative exists next to what your trying to integrate then you can use it.
However while studying Arc Length and surface of a revolution I came across a problem such that I had to integrate the following:
integrate from 0 to 8 sqrt(1+x)
Which can be done by substituting u=(1+x) and rewriting it. But I do not see how the derivative exists next to the function in this case? I am sure there are other examples but this is just one I came across. Could someone please enlighten me?
I would write
sqrt(1+x)dx=2sqrt(1+x)^2[(1/2)/sqrt(1+x)]dx
doing it your way
u=(1+x)
du=dx
which is present in the integrant
sqrt(1+x)dx->sqrt(u)du
I don't understand your issue, specifically the part I bolded. What's wrong with the initial function and with the substitution ?
x ---> x(u) (bijective correspondence) is valid for the substitution involved in your problem.
I just don't see how the derivative exists in this case, I guess, which is why I am confused. My best guess is that its 1 in in this case and 1 is implied to be there.
Well, they are linearly dependent one of another x=u-1 (u runs in the interval [1,9]) so dx/du = d/du (u-1) = 1.
  • · Replies 21 ·
