New Reply
flow coefficient and reynolds number
Share Thread Thread Tools
Feb26-11, 01:01 PM   #1
I don't understand why flow coefficient increases with Re and why it becomes independent after a certain Re number for orifice plates and venturi meter!
2. Relevant equations
3. The attempt at a solution
It seems than when the flow becomes turbulent, the flow coefficient becomes independent of Re but I still don't get it. Is it something to do with friction, velocity or viscosity?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Feb26-11, 02:14 PM   #2
The dependence of flow coefficient and Reynold's Number is strong when the flow is layared (i.e. laminar) and in the "transition" region between Re of 2000 to 4000. In the laminar region, the Darcy friction factor is determined exactly to be 64 / Re.
For turbulant flow, the dependence of flow coefficient on Reynolds number is still there but decays slowly. Thus, flow coefficients are approximated as constant for large Re.
New Reply
Thread Tools
Similar Threads for: flow coefficient and reynolds number
Thread Forum Replies
Small Reynolds Number Flow around Flat Plate Mechanical Engineering 2
Effect of reynolds number on flow in wave tank General Physics 0
Fluid Mechanics - Estimating Reynolds number and flow rate. Engineering, Comp Sci, & Technology Homework 1
change in flow / velocity direction and the Reynolds number General Physics 0
Reynolds number may have a similar effect to the Knudsen number Mechanical Engineering 0
