Gas expands adiabatically, find work.
  • Thread starter Thread starter keith river
    Gas Work
An Ideal Diatomic Gas expands adiabatically, resulting in a temperature decrease of 50 Kelvin. The work done by the gas can be determined using the formula W = Cv (dT), where Cv represents the specific heat at constant volume. The number of moles of the gas is calculated to be 125, based on a mass of 0.5 kg and a molar mass of 4. Importantly, the original temperature is not required to calculate the work done, as only the change in temperature is necessary.
  • Understanding of adiabatic processes in thermodynamics
  • Familiarity with the concept of specific heat at constant volume (Cv)
  • Knowledge of the ideal gas law and its applications
  • Basic calculations involving moles and molecular mass
  • Study the derivation of the work done in adiabatic processes
  • Learn about the specific heat capacities for diatomic gases
  • Explore the ideal gas law and its implications for thermodynamic calculations
  • Investigate the relationship between temperature, pressure, and volume in gas expansions
Students and professionals in physics and engineering, particularly those focusing on thermodynamics and gas behavior in adiabatic processes.
keith river
An Ideal Diatomic Gas expands adiabatically, the temperature after expansion is 50 kelvin less than its original temperature. What is the work done by this gas?
Assume you have 0.5 kg of the gas. Molar Mass = 4
I already know the gas is helium but I don't think knowing what the gas is helps solve the problem :(
I know all the internal energy = Work as there is no heat energy.
I was going to try using W = Cv (dT)
But without the original temp it won't get very far.
I worked out no. of moles = 500 / 4 = 125
Also no. of molecules = 7.525x10^25
I can't find any relation without volume or pressure which could tell me original temperature.
Is there a way to find the original temperature or am I going in the wrong direction?
That's a good thing, because it is not helium. Helium is monatomic.
Why?
You do not need to know the original temperature to determine the work done. All that matters is the change in temperature. (Hint: you were on the right track).
AM
  • · Replies 67 ·
  • · Replies 22 ·
  • · Replies 0 ·
  • · Replies 60 ·
11K
  • · Replies 33 ·
