How Do You Calculate Elevator Motion and Energy After a Cable Snap?
  • Thread starter Thread starter vtech
    Elevator
The discussion revolves around the dynamics of an elevator system after its cable snaps, focusing on the calculations of speed, energy, and motion involving a spring and frictional forces. The problem is situated within the context of mechanics, specifically dealing with energy conservation and forces acting on the elevator.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of conservation of energy to find the speed of the elevator before it hits the spring and the subsequent compression of the spring. There are questions about the signs in equations, particularly regarding compression and the role of friction in the calculations. Some participants share their equations and results while seeking confirmation or clarification on their approaches.
There is an active exchange of ideas with some participants providing guidance on specific parts of the problem, particularly in relation to the equations for compression and the effects of friction. Multiple interpretations of the equations are being explored, and participants are collaboratively troubleshooting their approaches without reaching a consensus on the final answers.
Participants express uncertainty regarding the correct application of signs in their equations, particularly in relation to compression and the influence of friction. There is also mention of constraints such as limited attempts to solve certain parts of the problem.
vtech
elevator problem - urgent help!
The cable of the 1800 kg elevator snaps when the elevator is at rest at the first floor, where the cab bottom is a distance d = 3.7 m above a cushioning spring whose spring constant is k = 0.15 MN/m. A safety device clamps the elevator against guide rails so that a constant frictional force of 4.4 kN opposes the motion of the elevator.
(image attached - i don't know how to make it embedded, sorry)
(a) Find the speed of the elevator just before it hits the spring._____ m/s
(b) Find the maximum distance x that the spring is compressed.______ m
(c) Find the distance that the elevator will bounce back up the shaft._____m
(d) Using conservation of energy, find the approximate total distance that the elevator will move before coming to rest._____m
alrite let's see...
a) I've gotten the first answer by dKinetic + dPotGrav (or Ug) + E thermal (from friction) = 0 from conservation of energy... solve for V final from the kinetic part... 7.37ms-1
b) i believe it should be -1/2mv^2 - mgS + 1/2kS^2 + F(of friction)*S = 0 but I'm not sure if I'm getting the signs wrong... should my answer be negative because its compressing or not?... not getting the right answer... help please!
c) now i need my result from b) as x and is it 1/2kx^2 = mg(d up) + Friction(s +d up) solve for (d up)... Note: not sure if should just use answer from b) times the friction force or is it friction * (d up)... instead of what my equation says...?
d) to be honest I'm sorry but i have no clue to this one... and without b) and c)... I'm having trouble understanding it...
i hope some1 can help me out?! thanks in advance!
Hmm, I am stuck on c) and d) too. but i can help you on b) you have it right but use the velocity you got in a) and if you have a TI-86 or higher just use solver to find distance from the quadratic equation you get.
I used: .5kS^2=.5mv^2-(force of friction)S+mgS
question?
i solved the quadratic, but is it the negative s because its in compression or not?...
i got either 0.90 or -0.72... I'm thinking its the positive... but i only have 1 try left... which one did u use? just want to make sure!
It is .9
but your equations for C and D don't work (I did the same thing as you did in C and the answer was wrong) so try it yourself and if it is still wrong were going to have to brainstorm.
actually, ur right... friction only acts during d up... my original equation had friction acting at (s + d up)
it should be:
1/2kx^2 = mg(d up) + Friction(d up)
other ?
hey randomphyre, i was wondering... have u gotten around to ch8 #66 part (c)... any clues? its the crates falling on the conveyor belt...
energy supplied by motor?
haha can get all the other parts except that. Its got me stumped too.
did u get d) for the elevator?
Ugrav (as a function of S + dup) = Uspring (as a function of S) + F(friction) L
solve for L... i thought it made sense... but i didn't get the right answer!... wut do u think??
  • · Replies 47 ·
9K
