AC Power RC series circuit low pass filter, find frequency given gain.
The discussion focuses on calculating the cutoff frequencies for a series AC power RC circuit configured as both a low pass and high pass filter. Given a 600 ohm resistor and a 73 nF capacitor, the calculated frequency for the low pass filter to achieve a gain of 0.25 is 5895 Hz, while the high pass filter configuration yields a frequency of 88424 Hz. The formulas used for these calculations are Vout/Vin = R / (R^2 + (1/ωC)^2)^(1/2) for the low pass filter and Vout/Vin = (1/ωC) / (R^2 + (1/ωC)^2)^(1/2) for the high pass filter.
  • Understanding of AC circuits and components
  • Knowledge of low pass and high pass filter configurations
  • Familiarity with the concepts of gain and frequency response
  • Proficiency in using the formulas for voltage gain in RC circuits
  • Study the design and analysis of RC filters in detail
  • Learn about the implications of filter cutoff frequencies on signal processing
  • Explore the effects of varying resistor and capacitor values on filter performance
  • Investigate the use of simulation tools like LTspice for circuit analysis
Electrical engineers, circuit designers, and students studying signal processing who are interested in understanding and designing AC power filters.
dfs730
1. You have a series circuit consisting of a ac power supply, a 600 ohm resistor and a 73 nF capacitor.
If the circuit is configured as a low pass filter, what frequency will cause the gain to be 0.25?
2. If the circuit is configured as a high pass filter, what frequency will cause the gain to be 0.25?
Vout/Vin = R / (R^2 + (1/ωC)^2)^(1/2) low pass filter
I tried to sub in for R,C, and gain (Vin/Vout) and got 5895 Hz for #1 and 88424 Hz for #2
any suggestions?
Check your RC layout for the low pass filter. The capacitor should be in a position to short out high frequencies, and allow low frequencies to pass.
