Domain & Range of f(x)=-√(t(1-t))
The discussion revolves around determining the domain and range of the function f(x) = -√(t(1-t)). Participants are exploring the implications of the function's structure and the effects of the negative sign in front of the radical.
  • Participants are questioning the range of the function, particularly the origin of the value -0.5. There is a focus on understanding the maximum value of the expression t(1-t) and its implications for the range of f(x).
Some participants have offered insights regarding the negative sign affecting the range, while others are exploring the maximum value of t(1-t) and its relevance to the function's behavior. There is an ongoing examination of the assumptions regarding the domain and range, with no clear consensus yet.
There is a noted discrepancy in the stated domain, with one participant suggesting it should be 0 ≤ t ≤ 1 instead of 0 ≤ t ≥ 1. The discussion is also constrained by a request to avoid using minimums in the analysis.
Procrastinate
f(x) = -√(t(1-t))
Domain: 0≤t≥1 (from Null Factor law)
Range: 0≤t
However, the range was wrong. The answers said that it was -0.5≤t≥0. I have no idea where the -0.5 came from. I substituted the domain values in but i didn't work. It just came out with zero.
Can anyone suggest any ideas without the use of minimums?
Procrastinate said:
f(x) = -√(t(1-t))
Range: 0≤t
Well, there is a minus sign on the front of that radical.
Now, what is the biggest value that the function t(1-t) attains?
I would say zero.
Procrastinate said:
I would say zero.
It isn't zero, but let's assume for the moment that it is zero. Since t(1-t) is under the radical, this would imply that the range of the function is simply 0 since nothing under the radical can be negative. This, in turn, implies that the function t(1-t) must be zero on the interval [0,1]. Clearly, this isn't the case, so 0 is not the highest value the function attains.
What about the midpoint of the interval [0,1]?
Procrastinate said:
f(x) = -√(t(1-t))
Quibble about what you wrote for the domain: it should be 0 ≤ t 1 .
  • · Replies 23 ·
  • · Replies 22 ·
