How can I calculate the time it takes to walk up a working escalator?
  • Thread starter Thread starter Phyzix
    Motion
The discussion focuses on calculating the time it takes to walk up a working escalator, given specific conditions. A user can walk up a stationary escalator in 30 seconds and can stand on a working escalator to reach the top in 20 seconds. By determining the velocities involved and applying the formula for distance, users can derive the total time to walk up the escalator while it is operational. The key takeaway is to combine the walking speed and escalator speed to find the total time required.
  • Understanding of basic kinematics, including distance, speed, and time calculations.
  • Familiarity with vector addition and motion in two dimensions.
  • Knowledge of acceleration and its effects on velocity over time.
  • Ability to apply algebraic formulas to solve for unknowns in motion problems.
  • Study the principles of kinematics, focusing on distance = velocity * time.
  • Learn about vector addition in physics, particularly in motion problems.
  • Explore real-world applications of acceleration and its impact on velocity.
  • Practice solving similar problems involving escalators and relative motion.
Students studying physics, educators teaching kinematics, and anyone interested in solving motion-related problems involving escalators and relative speeds.
Phyzix
OK---a rocket is launched at 53 degrees above horizontal with an initial speed of 100 m/s. It moves along its initial straight line path with an acceleraqtion of 30 m/s^2 for 3 seconds. At this time, the rocket is turned off and it proceeds to fall as a free body.
how can i find,A) the maximum height reached. B) the total time of flight. C) its horizontal range. ??
another problem I am having is the escalator problem which the vectors move in the same direction...
You notice you can walk up a stationary (broken) escalator in 30 seconds-- while you can go up in 20 seconds while it is working just by standing on it. How long would it take for you to WALK up the working escalator?
any help please?! :bugeye: :confused: :confused:
Have you TRIED anything?
You are told that the rocket moves along a straight line, making angle 53 degrees with the horizontal, with acceleration 30 m/s2.
You should know:
v = at+ v0 and x= (1/2)at2+ v0t so you can calculate the distance the rocket has moved on that line and its speed in that direction after 3 seconds.
Convert those to x and y coordinates (using sin(53) and cos(53)) and use them as
(x1,y1) and (vx1,vy1), new initial position and velocity vectors with acceleration -g in the y direction and 0 in the x direction.
Here is a very large hint. Velocities add.
The velocity of the escalator is distance ;/ time
d / 20 seconds
where d is some distance.
So:
Write a similar expression for the velocity at which you walk up the escalator.
Add the velocities together to get the total velocity.
Solve the formula distance = velocity * time for the time it takes to go up at the new velocity which is the sum.
You will find you won't be able to solve for 'd', but you don't need to.
  • · Replies 38 ·
