DC charging circuit Calculating I, V, and Z?
The discussion revolves around the calculations and principles involved in DC resonant charging circuits, particularly in the context of their applications in radar technology. Participants raise questions about determining maximum current, current rise time, and the behavior of the circuit with a diode and a duty cycle pulse.
  • One participant inquires about the appropriate methods to calculate maximum current in the circuit, suggesting options like characteristic impedance and circuit series resistance.
  • Another participant questions how to calculate current rise time, proposing L/R and RC time constants or the di/dt = v/L relationship.
  • A question is posed regarding the effect of a diode in the LC circuit when subjected to a 50% duty cycle pulse, specifically whether the inductor field collapse would also follow a 50% duty cycle.
  • One participant provides an example circuit that includes an AC transformer and a rectifier, describing it as a charging choke and capacitor setup.
  • A reference to a book on radar principles is made, which includes a description of the circuit and its operational theory.
  • Another participant suggests that the calculations should assume a power supply with zero impedance and mentions using a circuit analysis program to determine peak current.
  • The resonant frequency formula is introduced, indicating that rise time is consistent with circuits operating at that frequency.
  • It is stated that the LC circuit is always charged by a DC source, although the implications of this statement are not fully explored.
Participants express various viewpoints on the calculations and principles related to DC resonant charging circuits, with no clear consensus reached on the methods or interpretations of the questions posed.
Some assumptions about circuit conditions, such as the impedance of the power supply, are not explicitly stated. The discussion also reflects a mix of theoretical and practical considerations, with references to specific applications and literature.
HMS-776
I have a few questions on DC resonant charging circuits. The circuit only has a few practical applications, most noteably Radar and there is very little info online about it. If anyone could help, I would be very thankful...
1. What would be used to calculate max current in the circuit?
-Characteristic Impedance
-Circuit Series Resistance
-Characteristic Impedance and Circuit Series Resistance
-Neither?
2. What would be used to calculate current rise time in the circuit
-L/R and RC time constants
-di/dt=v/L
-Neither
3. If the LC circuit has a diode placed in it, and the circuit were given a 50% duty cycle pulse, would the inductor field collapse also be 50% duty cycle, causing the cap to be charged by a DC, instead of a pulsed DC source?
-Neither?
-di/dt=v/L
-Neither
Do you have a link to the circuit, or can you post an example? "DC" and "resonant" don't usually go together...
The book
Principles of Radar
Third edition
By Reintjes & Coate
Has a description of this circuit with theory of operation.
Assuming that you are asking about resonant charging circuit only:
If I were doing the calculating, would do it as follows
1 Assume that have power supply with zero impedance.
This power supply is suddenly connected to an inductor (charging reactor) in series with a capacitor (total capacitance of pulse forming network)
It should then be easy to use a circuit analysis program to calculate the peak current on the first cycle.
2 Fr=1/(2*pi*(LC)^1/2)
Fr is resonant frequency
L and C as above
Rise time is the same as a circuit with this frequency.
3 The LC circcuit is always charged by a DC source.
  • · Replies 19 ·
