Calc 2 problem involving integration
  • Thread starter Thread starter bennwalton
    Calc 2 Integration
The discussion revolves around a calculus problem involving integration, specifically focusing on finding the values of a function defined on a closed interval based on its derivative, which includes a line segment and a semicircle. The original poster shares their approach to finding f(-3) and expresses confusion regarding the calculation of f(4).
  • The original poster attempts to find f(-3) by integrating the derivative f'(x) over the interval [-3, 0] and questions how to approach finding f(4), particularly whether to include the integral from [-3, 0] or just from [0, 4].
  • Some participants question the original poster's calculations and suggest evaluating the integral graphically to determine the areas above and below the x-axis.
  • Others suggest using the area of geometric shapes to assist in finding f(4) and emphasize the relationship between the integral of f'(x) and the values of f at specific points.
The discussion is ongoing, with participants providing different perspectives on how to approach the problem. Some guidance has been offered regarding the evaluation of integrals and the interpretation of areas under the curve, but there is no explicit consensus on the correct method to find f(4).
Participants note the importance of understanding the areas represented by the graph of f' and how they relate to the values of f. There is mention of potential confusion regarding the setup of the problem and the notation used in the original poster's calculations.
bennwalton
Hey everyone! My name is Ben, I'm a senior in high school working on an BC Calc problem and am having some general questions about it.
The question reads:
Let f be a function defined on the closed interval [-3,4] with f(0) = 3. The graph of f', the derivative of f, consists of one line segment and a semi circle, as shown above.
Then they provide this image:
http://t0.gstatic.com/images?q=tbn:ANd9GcS5nCFcatsgGUIOnZXhKAObqzlF7qkiuW5MOX13BQcePo0e-N3jGQ&t=1
Letter D reads:
Find f(-3) and f(4). Show the work that leads to your answers.
To find f(-3), I found an equation for the line of f'(x) on x: [-3,0]. I found the equation to be y' = -x - 2. I then recovered the original function on that same interval, and found y = -x2/2 - 2x + C. I used the point (0,3) to find C because of the f(0) = 3 and found that f(x) = -x2 - 2x + 3 (all of this only on the interval [-3,0]. I then plugged in -3 into this recovered equation to find f(-3) = 9/2.
For whatever reason though, the second question baffled me. I tried to integrate geometrically again (as from 0 to 4 it's a semicircle of r=2 cut out of a rectangle of dimensions 2x4) and came up with the answer 8-2π (that's supposed to be a pi symbol...).
I guess my primary question is, do I add to that the integral of the other side? Would f(4) be the integral from [-3,0] + [0,4], or simply the integral from [0,4]? Do I use the equation of a circle to do something similar; do I have to integrate that?
Thanks so much! It's a wonder that a site like this exists :P
First of all, I assume you mean f(0) = 3.
How did you get 9/2 when integrating f '(x) from ‒3 to 0 ?
From ‒3 to ‒2, there is an area of 1/2 above the x-axis.
From ‒2 to 0, there is an area of 2, which is below the x-axis. That translated to an integral of ‒2.
That gives a result of ‒3/2.​
In general:
[tex]\int_a^bf'(x)\,dx=f(b)-f(a)[/tex]
That's about all you need.
Sorry about the notation mistake, having to hold down shift to do all my parentheses must have thrown me off; a mere typo.
Alas, I mixed up what I was doing when typing out my method.
To find f(-3), I found an equation for the line of f'(x) on x: [-3,0]. I found the equation to be y' = -x - 2. I then recovered the original function on that same interval, and found y = -x2/2 - 2x + C. I used the point (0,3) to find C because of the f(0) = 3 and found that f(x) = -x2 - 2x + 3 (all of this only on the interval [-3,0]. I then plugged in -3 into this recovered equation to find f(-3).
Does that make sense? I'm sorry my work is all kind of jumbled on my sheet, I wrote out my process for a different part of the problem but matched it with the answer I got for this one...
So in light of having done that, how would I find f(4)? The graph to the right of the origin is a semi circle with radius 2; x2 + y2 = 4. which would lead to y = sqrt (4 - x2). But that's as far as I know how to go
Finding f(‒3):
Yes, that's one way to find f(‒3).
What I suggested went along with evaluating the integral graphically. There is more area below the x-axis than above on the interval [‒3, 0]. The area is ‒3/2.
Therefore, f(‒3) ‒ f(0) = ‒3/2 . Plug 3 in for f(0) and solve for f(‒3). Did you get f(‒3) = 3/2 ?​
Find f(4) in a similar way.
What is the area between f '(x) and the x-axis on the interval [0, 4] ?
It looks to me like it's the area of a 4×2 rectangle minus half the area of a circle of radius 2. (Of course this answer is negative since it's below the x-axis.)
Since f(x) is the anti-derivative of f '(x), the area is equal to f(4) ‒ f(0) .
  • · Replies 105 ·
13K
