Simpson's Rule in MATLAB: Single vs Composite
  • Context: MATLAB
  • Thread starter Thread starter tironel
    Matlab
The discussion centers on implementing Simpson's Rule in MATLAB, specifically comparing the Composite 1/3 Simpson's Rule with a single application of Simpson's Rule. The user successfully programmed the Composite version but is uncertain about the implementation of the single application. It is confirmed that setting n=1 in the Composite function will yield results equivalent to a single application of Simpson's Rule. The provided MATLAB function, P_simpson13, calculates the integral using the Composite method.
  • Understanding of numerical integration techniques, specifically Simpson's Rule
  • Proficiency in MATLAB programming
  • Familiarity with function handles in MATLAB
  • Knowledge of loop constructs in MATLAB
  • Research the built-in MATLAB functions for numerical integration, such as integral
  • Learn how to implement a single application of Simpson's Rule in MATLAB
  • Explore error analysis in numerical integration methods
  • Investigate the differences between Composite Simpson's Rule and other numerical methods like Trapezoidal Rule
Students and educators in mathematics or engineering fields, MATLAB programmers, and anyone interested in numerical methods for integration.
tironel
Ok I just completed a homework assignment by programming a Composite 1/3 Simpson's rule in matlab. However, I am asked to compare my results from a single application of Simpaon's rule with my results. I do not know how to program a single application of Simpson's rule in MATLAB or does MATLAB have a built in function? However I will attach my code below and if I set n=1 then it seems to me that it would be the same result as a single application of Simpson's rule, am I correct?
Code:
function F =P_simpson13(func,a,b,n)
%a=initial value
%b=end value
%n=number of double intervals of size 2h
 n = 2 * n;
h = (b - a) / n;
S = func(a); % S is continuing sum
for i = 1 : 2 : n-1 %all odd steps
    x = a + h .* i;
    S = S + 4 * func(x);
end
for i = 2 : 2 : n-2 %all even
    x = a + h .* i;
    S = S + 2 * func(x);
end
S = S + func(b);
F = h * S / 3;
F;
end
You completed the assignment by copying the MATLAB code in the Simpson's Rule wiki virtually line by line?
I would guess that's why you don't know the answer to this question. Had you written it, you might have understood it better.
18K
