Edge Plasma Physics: Key Considerations for PIC Codes & Simulations
This discussion focuses on key considerations for developing Particle-In-Cell (PIC) codes and simulations in edge plasma physics, particularly in the context of tokamaks. Essential factors include the electron sheath dynamics at the walls and diagnostic devices, the presence of non-Maxwellian distributions, and the significant temperature and electric potential gradients. Additionally, it is crucial to account for the electron-Larmor radius being larger than the grid cell dimensions in PIC simulations. The discussion also highlights the impact of neutral density near the plasma edge and its implications for contamination and heating methods such as neutral beam injection and microwave heating.
  • Understanding of edge plasma physics in tokamaks
  • Familiarity with Particle-In-Cell (PIC) simulation techniques
  • Knowledge of electron sheath behavior and diagnostics
  • Concepts of non-Maxwellian particle distributions
  • Research the effects of electron sheath dynamics on plasma confinement
  • Explore advanced PIC simulation techniques for edge plasma modeling
  • Investigate the implications of non-Maxwellian distributions in plasma behavior
  • Learn about heating methods in plasma physics, including neutral beam injection and microwave heating
Researchers and engineers in plasma physics, particularly those involved in tokamak design and operation, as well as developers of simulation codes for edge plasma behavior.
LuisVela
Hello everybody.
Im starting a project on the basic processed undergoing in the edge plasma region. ( I mean, near the walls of a plasma confining device, like a tokamak or so.)
I was wondering if you could name some ''things'' I should be aware of in order to make a small PIC code or computer simulation.
I came up with these ones:
1.) Electron sheath on the walls, and over diagnostic devices (Probes and so on..).
2.) Non-Maxwellian distribution near the edge.
3.) High gradients on temperature & electric potential.
4.) In case of a PIC code, be awarer that the electron-larmor radius is bigger than the dimensions of the cell composing the grid.
...any suggestions?
There would be a greater density of neutrals near the edge of the plasma. If the plasma (neutral) make it to the wall, then there are spallation reactions with the wall, and that is the source of contamination (of higher Z atoms) in the plasma. If the current density is greater in the sheath, then the sheath temperature is higher and the heat must be conducted to the interior.
The heating might also be accomplished by neutral beam injection, microwave heating and compression.
