Solving "6. [SFHS99 5.P.60.]" Physics Problem
  • Thread starter Thread starter splinter
    Block Wall
The discussion revolves around a physics problem involving a block being pushed up a vertical wall at a constant speed. The problem includes determining the work done by various forces, including gravity, and calculating the normal force acting on the block. The subject area includes concepts of forces, work, and friction in a mechanics context.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of Newton's laws and the components of forces acting on the block. There are attempts to calculate gravitational force and its components, as well as the normal force and frictional force. Questions arise regarding the correct interpretation of the problem and the calculations involved.
Some participants have made progress in calculating forces and work done, while others express confusion about specific steps and the correctness of their calculations. There is an acknowledgment of the need to focus on the specific work done by gravity rather than friction, indicating a shift in understanding. The discussion reflects a mix of interpretations and attempts to clarify the problem.
Participants mention the constant speed of the block and the angle of the applied force, which are crucial to the problem setup. There is also a reference to the coefficient of kinetic friction and the need to consider the work done by various forces, highlighting the complexity of the scenario.
splinter
Hey everyone, my first post here, hope it's ok that it's a question...
I've got this physics problem that is absolutely stumping me, is abnormal from all the other forces problems I've done before, and uk is throwing me for a loop too...here it is:
6. [SFHS99 5.P.60.] A 5.5 kg block is pushed 3.1 m at a constant speed up a vertical wall by a constant force applied at an angle of 30.0° with the horizontal, as shown in Figure 5-23.
Figure 5-23
Assume that the coefficient of kinetic friction between the block and the wall is 0.30.
(a) Determine the work done by the force on the block
___________________ J
(b) Determine the work done by gravity on the block.
(c) Determine the normal force between the block and the wall.
___________________ N
Any help or hints you guys can give me would be greatly appreciated...this one has me stumped.
You know there will be a normal force, find out which will it be equal to, remember the block isn't moving the x-axis so the Fx sum is zero.
Also Remember Newton's 1st Law
[tex]\sum_{i=1}^{n} \vec{F}_{i} = 0 \rightarrow \vec{v} = constant[/tex]
Think in components of the applied force.
Ok so I tried taking the gravitational force, 54.96N, and finding the horizontal component of that. I drew it as a triangle with 54.96N as the y leg, then did 53.96/tan 30 to find the x leg of the triangle. This gave me 93.46N, which my online homework is saying is wrong! Still confused =\
Applying Newton's 1st Law
on x-axis
[tex]Fcos\theta - N = 0[/tex]
[tex]Fcos\theta = N[/tex]
On y-axis
[tex]Fsin\theta - mg - F_{f} = 0[/tex]
[tex]F_{f} = \mu N[/tex]
[tex]Fsin\theta - mg -\mu Fcos\theta = 0[/tex]
Gravity will have a negative work because it forms 180 degrees with the displacement vector, and [itex]Fsin\theta[/itex] will do the work pushing the block up.
Also remember Work definition
[tex]W = \vec{F} \cdot \vec{r}[/tex]
where W is equal to
[tex]W = |\vec{F}||\vec{r}|cos\theta[/tex]
where [itex]\theta[/itex] is the angle between the radius vector and the force.
ok I've gotten the Fapp and the Fn, now I'm just having trouble with the Ff. I used the equation Ff = uN, plugging in my normal force of 194.5 and u of .3, then multiplied that by 3.1 to get work, and entered the negative of that, but it's still telling me its incorrect. Don't understand what I'm doing wrong!
Didn't see your new post and edit, might be able to get it with that.
Read the questions again, it does not ask for work done by friction... I also decided to delete my energetic solution, because it wasn't needed.
Whoops it was work done by gravity...easy just mgd. doh! Thanks for the help i got them all now.
It was a pleasure to be of help, and welcome to PF!
  • · Replies 16 ·
