New Reply
Vertical circular motion in uniform circular motion
Share Thread Thread Tools
Mar6-11, 10:00 AM   #1
A pilot flies an airplane in a vertical circular loop with a radius of R = 1200 m. The plane is gaining speed as the pilot makes a dive, and its speed is measured to be 150 m/s when the plane reaches the bottom of the circle. If the total acceleration of the plane at the bottom is 2.3g, find (a) the tangential acceleration of the plane, (b) the direction of the plane’s acceleration at the bottom of the loop.
2. Relevant equations
What I can think of doing, is:
an=v2/R
and
a = an + at
3. The attempt at a solution
I tried making a free body diagram with the total force and an pointing toward the center, and the v and the at point to the right. At the bottom of the circle.
an = 1502/1200 = 18.75m/s2
a = 2.3g = 2.3/9.8m/s2 = 0.2346m/s2
but this doesn't give me my answer. The answer is (a) 12.5 m/s2 and (b) beta = 56.3o
(i dont know how to do a, so I cant start b)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Mar6-11, 10:27 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by seanpk92 View Post
an=v2/R
yes, good
and
a = an + at
the tangential and centripetal acceleration vectors are at right angles to each other, so you need to add them vectorially to get the total acceleartaion.
yes
]and the v and the at point to the right.
yes, and the tangential force points in the same direction
2.3 g's means the acceleration is 2.3 times the gravitational acceleration
Correct you formula for total acceleration
Mar6-11, 10:47 AM   #3
Thank you so much PhantomJay!
Mar6-11, 11:01 AM   #4
Recognitions:
(You're) Welcome to PF!
New Reply
Thread Tools
Similar Threads for: Vertical circular motion in uniform circular motion
Thread Forum Replies
Uniform circular motion - plane in a circular arc Introductory Physics Homework 1
uniform vertical circular motion Introductory Physics Homework 12
A car goes around a vertical circle (Uniform Circular Motion) Introductory Physics Homework 4
Vertical Circles and Non-Uniform Circular Motion Introductory Physics Homework 6
Uniform Circular Motion, Rotational Motion, Torque, and Inertia General Physics 1
