Mixing of two gasses. Find the temperature and pressure
The discussion focuses on calculating the final temperature and pressure after mixing two gases in a rigid insulated tank. Room A contains air at 250 kPa and 300 K, while Room B has air at 150 kPa and 1000 K. The ideal gas law, represented by the equation PV=mRT, was utilized to determine the masses of the gases, yielding values of 1.452 kg for Room A and 0.523 kg for Room B. The final temperature was calculated using the specific heat capacities, resulting in a final temperature of 680.5 K.
  • Understanding of the Ideal Gas Law (PV=mRT)
  • Knowledge of specific heat capacities (Cv)
  • Familiarity with internal energy concepts
  • Basic thermodynamics principles regarding insulated systems
  • Study the application of the Ideal Gas Law in different thermodynamic processes
  • Learn about specific heat capacities for various gases and their significance
  • Explore the concept of internal energy and its role in thermodynamic systems
  • Investigate the principles of energy conservation in insulated systems
Students and professionals in thermodynamics, mechanical engineers, and anyone involved in gas mixture calculations and energy transfer analysis.
Xyius
A rigid insulated tank is separated into two rooms by a stiff plate. Room A of 0.5 m3 contains air at 250 kPa, 300 K and room B of 1 m3 has air at 150 kPa, 1000 K. The plate is removed and the air comes to a uniform state without any heat transfer. Find the final pressure and temperature.
I am pretty sure these are the ones I am going to use.
[tex]PV=mRT[/tex]
[tex]/delta u = c_{v}/delta T[/tex]
Well I figured I would find the mass of each gas in their rooms first. So I just used the ideal gas law on both of them..
[tex]m=\frac{PV}{RT} \rightarrow m_{1}=1.452kg,m_{2}=0.523kg[/tex]
Therefore, at the final state the ideal gas equation is known except for T and P. I figured the equation [tex]/delta u = c_{v}/delta T[/tex] might be useful but I do not understand how I could get temperature from this. All I need is one and I can find the other via the ideal gas law.
Thanks! :]
Ohh I think I have figured it out! But I will post my solution for anyone else with the same problem. :]
The internal energy lost from the hotter has, is equal to the internal energy gained from the cooler gas. Using the formula for specific heats..
[tex]C_{v1}(T_{f}-T_{i})+C_{v2}(T_{f}-T_{i})=0[/tex]
Then I just got the C values from the tables and got a final temp of 680.5K. :]
  • · Replies 18 ·
  • · Replies 35 ·
