Physical significance of vdP (Thermodynamics)
The discussion centers on the physical significance of the term vdP in thermodynamics, particularly in relation to enthalpy and heat transfer. Participants explore the implications of this term in various thermodynamic processes, including adiabatic free expansion, and its relationship to internal and external pressures.
  • Some participants assert that the term vdP represents the work associated with displacing a system with volume V over a pressure difference dp, which is crucial for understanding the difference between enthalpy and heat transfer.
  • Others highlight that at constant pressure, the term vdP equals zero, leading to the conclusion that dH equals dQ.
  • There is a question regarding the relationship between the term vdP and entropy change during processes such as adiabatic free expansion, where heat transfer is absent.
  • Some participants express uncertainty about how the energy associated with the term vdP manifests and how it can be measured, particularly in relation to internal energy and work.
  • Concerns are raised about the lack of distinction between internal and external pressure in reversible thermodynamics, which complicates the understanding of the vdP term.
Participants express differing views on the significance and implications of the vdP term, indicating that multiple competing perspectives remain without a clear consensus.
Participants note the complexity of measuring energy differences and the potential effects of the term vdP on properties like entropy, suggesting that assumptions about constant conditions may influence interpretations.
Shivanand
The difference between Enthalpy and Heat transfer is the term vdP as
dH-dQ=vdP
What is the physical significance of the term vdP? :rolleyes:
Wherever an article describes the difference between enthalpy and heat transfer, it is stated that heat transfer and enthalpy are same at constant pressure as vdP=0
Why does everyone avoid dealing with the term? :confused:
And during adiabatic free expansion of a gas, what happens to the enthalpy? Heat transfer is absent, so dH = [STRIKE]dQ[/STRIKE] + vdP
Is the term related to the entropy change in this process? :approve:
Science news on Phys.org
The problem with the Vdp term as related to enthalpy, arrises from a lack of distinction in (reversible) thermodynamics between the internal and external pressure.
The attachment in https://www.physicsforums.com/showthread.php?t=88987&referrerid=219693 , (post#7) might help you out. The Vdp term stands for work needed or obtained from displacing a system with volume V over a pressure-difference dp, and fits with the formulation of the first law as dH=Q+We, where We is the usefull work done on the system.
dH-dQ=vdP
VdP is the contribution of the energy of a system with volume V whne the pressure changes by dP. If you keep the pressure constant then dP=0 and dH=dQ.
The attachment in https://www.physicsforums.com/showthr...errerid=219693 , (post#7) might help you out. The Vdp term stands for work needed or obtained from displacing a system with volume V over a pressure-difference dp, and fits with the formulation of the first law as dH=Q+We, where We is the usefull work done on the system
I will check your link and reply soon. Thanks for your help :)
How does the energy manifest itself and how would it be measurable? It is known that we can measure internal energy (dU) and also work (pdV). What are the possible ways in which the term Vdp affects the properties (like entropy) ?
One meusures energy differences, using the first law, keeping some of the terms constant, observing the shift in the others, and converting it to energy changes.
Similarly for entropy changes.
  • · Replies 22 ·
