How Can I Safely Conduct Liquid Sodium Wicking Experiments in a Sealed Tube?
This discussion focuses on conducting liquid sodium wicking experiments in a sealed tube under high temperatures (300-400 degrees Celsius). The recommended setup includes using solid sodium pellets in a tube purged with Argon, with considerations for safety and observation. A reference paper by T. Gnanasekaran et al. is suggested for further reading on materials and methods. The use of quartz tubes is discussed, along with the necessity of performing the experiment in an inert atmosphere, such as a glove box, to mitigate risks associated with sodium's reactivity.
  • Understanding of liquid sodium properties and reactivity
  • Knowledge of high-temperature experimental setups
  • Familiarity with inert gas purging techniques
  • Experience with safety protocols for hazardous materials
  • Research the use of quartz tubes for high-temperature sodium experiments
  • Learn about inert gas glove box setups for chemical experiments
  • Investigate safety measures for handling reactive metals like sodium
  • Review the referenced paper on stability of ternary oxygen compounds in liquid sodium
Researchers, chemists, and engineers involved in high-temperature experiments with reactive materials, particularly those working with liquid sodium and its applications in nuclear materials.
dpage
I need to test a system for liquid sodium wicking under high temperatures. The setup is as follows:
Solid sodium pellets are placed in a tube which is then purged of oxygen (replaced with Argon). The tube is sealed and then heated to 300-400 degrees Celsius and agitated with a shaking mechanism.​
My questions are the following:
Where can I find a good reference on setting up sealed tube experiments(i.e. materials, methods to seal the tube, etc...)?
It is preferable that the tube be transparent for observation. What type of tube might I use(is quartz o.k. with sodium at these High temperatures?)?
What additional safety precautions are needed in case the tube cracks? It seems like an outer metal cylinder is typically used for this, but this is not possible for an experiment involving agitation. Also we would like to be able to observe...Anything we can do besides have a fire extinguisher on hand??​
Much Thanks,
dpage
Try reviewing this paper: T. Gnanasekaran, K.H. Mahendran, G. Periaswami, C.K. Mathews, H.U. Borgstedt, Stability of ternary oxygen compounds of molybdenum in liquid sodium, Journal of Nuclear Materials, Volume 150, Issue 2, October 1987, Pages 113-127, ISSN 0022-3115, DOI: 10.1016/0022-3115(87)90068-7.
(http://www.sciencedirect.com/science/article/B6TXN-480TP8C-1PN/2/bb6423754f402fbe9be88e35a892ce0f)
See if they used a quartz crucible with liquid sodium, or perhaps asked someone in the chemistry department.
It may be possible to use a quartz tube, e.g., a test tube that is then sealed at the top.
I'd purge the oxygen first before admitting the sodium, which is probably stored in oil or inert gas.
Peform the experiement in a glove box or chamber in an iner gas, e.g., argon.
If one cannot use a glass or transparent ceramic, then one would have to use something like a stainless steel, or perhaps aluminum tube. In that case, one would have to use X-rays to view inside, and that requires radiation protection/shielding.
Folks have looked at sodium bonded fuel elements.
