Photon stopping an object travelling at 10m/s
  • Thread starter Thread starter Mr.A.Gibson
    Photon
The discussion revolves around the momentum of photons and their interaction with an object moving at 10 m/s. Participants explore the implications of conservation of energy and momentum in the context of elastic collisions involving photons.
  • Participants examine the relationship between the momentum of the photon and the mass of the object, questioning the assumption that the mass must be zero for the object to be stopped. They discuss the change in momentum of the photon and its implications for the conservation equations.
The discussion is active, with participants questioning each other's reasoning and attempting to clarify the assumptions made regarding the mass of the object and the momentum of the photon. Some guidance is offered through hints about the change in momentum, but no consensus has been reached.
Participants are working under the constraints of conservation laws and the specific scenario of elastic reflection, which may influence their interpretations and assumptions about mass and momentum.
Mr.A.Gibson
The momentum of a photon is ħk, where k is the wave vector. Assume an object moving at 10m/s, objects of which mass can be stopped by elastic reflection of the photon.
Conservation of energy and momentum
p = ħk = h/λ
Assume the photon is traveling in the opposite direction to the object. Then the mass of the object has to be 0. I feel I'm missing something?
How did you conclude this?
Hint: What's the change in momentum of the photon?
conservation of momentum,
[tex] p_b+10m=p_a[/tex]
subscripts refers to photons momentum before and after collision.
Then from conservation of energy
[tex] \frac{1}{2}mv^2+cp_b=cp_a[/tex]
substitute in the first equation and velocity of the object to give
[tex] 50m+cp_b=c(p_b+10m)[/tex]
[tex] 50m=10cm[/tex]
only valid if m=0
2ħk = 10m
m = ħk/10
Makes sense, what did I mess up in the first place then?
