Particular Solution of an Inhomogeneous Second Order ODE
The discussion revolves around finding a particular solution to the inhomogeneous second-order ordinary differential equation (ODE) given by y'' + 4y = tan(x). Participants are examining various methods to approach the problem, including variation of parameters and the D operator technique.
  • Mixed
  • The original poster attempts to use variation of parameters with specific solutions for the homogeneous part but expresses uncertainty about their correctness. Other participants suggest reconsidering the homogeneous solutions, indicating they should involve cos(2x) and sin(2x). There is also a mention of using the D operator method to derive the complementary function.
Participants are exploring different methods for solving the ODE, with some providing guidance on the correct form of the homogeneous solutions. There is a recognition of the need to clarify the fundamental set when dealing with the function tan(x). The discussion reflects a mix of attempts and suggestions without a clear consensus on the best approach yet.
There is an indication that the lesson context involves variation of parameters, which may influence the methods being discussed. Additionally, the original poster expresses concern about missing fundamental aspects of the problem.
0131413
A particular solution of y'' + 4y = tanx
Answer choices are:
(a) 1/2*cos(2x)ln|sec(2x)+tan(2x)|
(b) -1/2*cos(2x)ln|sec(2x)+tan(2x)|
(c) 1/2*sin(2x)(ln*cos(x)+x*sec(2x))
(d) 1/2*sin(2x)(ln*cos(x)-x*sec(2x))
(e) none of the above
I used variation of parameters with y1=cos(x) and y2=sin(x)
Wronskian(cos(x) sin(x))=1
yp=-v1y1+v2y2
v1'=sin(x)tan(x)
=(sin(x))^2/cos(x)
=(1-(cos(x))^2)/cos(x)
=1/cos(x)-cos(x)
v1=ln|tan(x)+sec(x)|-sin(x)
v2'=cos(x)tan(x)
=sin(x)
v2=-cos(x)
yp=-cos(x)(ln|tan(x)+sec(x)|-sin(x))+sin(x)(-cos(x))
=-cos(x)ln|tan(x)+sec(x)|+cos(x)sin(x)-sin(x)cos(x)
Given the answer choices, now I feel like I've missed something fundamental. It's probably obvious. So sorry.
The solutions to the homogeneous part are not correct. Think cos(2x) and sin(2x).
Why not use the normal method?
Rewriting in terms of the D operator,
(D² + 4)y = tan(x).
The auxiliary equation of this D.E. is D = ±2i, henceforth we obtain the complementary function to be -:
CF = e0[c1cos2x + c2sin2x]
For a function such as tan(x), the particular integral is given by -:
)(D%20-%202i)}tan(x)%20=%20\frac{1}{4i}[\frac{1}{D%20-%202i}%20-%20\frac{1}{D%20+%202i}](tan(x)).gif
Operating separately, we have -:
and
Once you compute these integrals, the complete solution of the differential equation will be given by -:
CS = CF + PI
(D² + 4)y = tan(x).
and
CS = CF + PI
Thanks a lot. I understand now. I was not sure about the fundamental set when dealing with tan(x), but I see it now.
SVXX: Because the lesson was on variation of parameters. :wink:
  • · Replies 22 ·
