Electrical Machines and Power Electronics - 3 phase, 6 pole induction motor
The discussion focuses on the calculations for a three-phase, 6-pole, \Delta connected induction motor rated at 208V and 60Hz. The starting torque calculated for the motor in Y connection is 11.68 Nm, with both phase and line currents equal to 10 A. In the \Delta connection, the torque increases to 35 Nm, while the phase current is 17.34 A and the line current is 30 A. These calculations utilize specific equations related to induction machines and confirm the accuracy of the results presented.
  • Understanding of three-phase induction motors
  • Familiarity with electrical circuit analysis
  • Knowledge of torque calculations in electrical machines
  • Proficiency in using complex numbers for impedance calculations
  • Study the principles of torque generation in induction motors
  • Learn about the differences between Y and \Delta starting methods
  • Explore the impact of rotor resistance on motor performance
  • Investigate the use of simulation tools for motor analysis, such as MATLAB or Simulink
Electrical engineering students, motor design engineers, and professionals involved in the analysis and optimization of induction motor performance.
VinnyCee
A three phase, 6-pole, [itex]\Delta[/itex] connected induction motor is rated 208V, 60Hz. It has [itex]R_R\,=\,5.2\,\Omega[/itex], [itex]R_S\,=\,2.2\,\Omega[/itex], [itex]X_m\,=\,220\,\Omega[/itex], [itex]X_{lr}\,=\,7.5\,\Omega[/itex], [itex]X_{ls}\,=\,2.3\,\Omega[/itex].
Calculate the starting torque and both phase and line currents when the motor is started in [itex]\Delta[/itex] and Y.
Various equations from the notes about induction machines and multiple pole pairs.
[tex]I_{S,\,Y}\,=\,\frac{\frac{V_{rated}}{\sqrt{3}}}{(R_S\,+\,j\,X_{ls})+(j\,X_m\,||\,R_R\,+\,j\,X_{lr})}[/tex]
[tex]T_Y\,=\,3\,\cdot\,\frac{P_{gap}}{\omega_s}\,\cdot\,\frac{p}{2}[/tex]
[tex]I_{R,\,Y}\,=\,I_{S,\,Y}\,\cdot\,\frac{j\,X_m}{R_R\,+\,j\,X_{lr}\,+\,j\,X_m}[/tex]
[tex]P_{gap}\,=\,|I_{R,\,Y}|\,\cdot\,R_R[/tex]
[tex]I_{S,\,Y}\,=\,\frac{\frac{208}{\sqrt{3}}}{(2.2\,+\,j\,2.3)+(j\,220\,||\,5.2\,+\,j\,7.5)}\,=\,10\,\angle\,-53.8^{\circ}[/tex]
In Y, the line current is same as phase current above, right?
I get the torque in Y as [itex]T_Y\,=\,11.68\,Nm[/itex].
Does that look right?
This is correct. The solutions also state...
[tex]I_{ph,\,Y}\,=\,|I_{S,\,Y}|\,=\,10\,A[/tex]
[tex]I_{l,\,Y}\,=\,I_{ph,\,Y}\,=\,10\,A[/tex]
And for [itex]\Delta[/itex]:
[tex]T_{\Delta}\,=\,3\,\cdot\,T_Y\,=\,35\,A[/tex]
[tex]I_{ph,\,\Delta}\,=\,\frac{208}{120}\,\cdot\,10\,=\,17.34\,A[/tex]
[tex]I_{l,\,\Delta}\,=\,\sqrt{3}\,\cdot\,I_{ph,\,\Delta}\,=\,30\,A[/tex]
