How Does Transcranial Magnetic Stimulation Induce EMF in Brain Tissue?
  • Thread starter Thread starter imapeiceofwod
    Figure
The discussion revolves around the application of transcranial magnetic stimulation (TMS) and its effects on brain tissue, specifically focusing on the induced electromotive force (emf) due to changing magnetic fields. The problem includes calculations related to induced emf in a circular area of brain tissue and the electric field generated by a solenoid with oscillating current.
  • Participants discuss the application of Faraday's Law to determine induced emf and electric fields. There are inquiries about specific calculations and attempts to understand the relationship between magnetic flux and induced emf.
Some participants have provided hints regarding the use of Faraday's Law and suggested calculating changes in magnetic flux. However, there is a lack of explicit consensus, with some participants expressing difficulty in understanding the concepts and requesting further examples.
Participants have noted the importance of Maxwell's equations and the specific parameters given in the problem, such as the rate of change of magnetic fields and the dimensions of the solenoid. There is an emphasis on understanding the underlying principles rather than simply applying formulas.
imapeiceofwod
Transcranial magnetic stimulation (TMS) is a noninvasive technique used to stimulate regions of the human brain. In TMS, a small coil is placed on the scalp and a brief burst of current in the coil produces a rapidly changing magnetic field inside the brain. The induced emf can stimulate neuronal activity.
(a) One such device generates an upward magnetic field within the brain that rises from zero to 1.50 T in 125 ms. Determine the induced emf around a horizontal circle of tissue of radius 1.70 mm.
magnitude 109 µV
(b) The field next changes to 0.500 T downward in 95.0 ms. How does the emf induced in this process co
A long solenoid with 6.50 102 turns per meter and radius 2.00 cm carries an oscillating current I = 3.00 sin 90πt, where I is in amperes and t is in seconds.
(a) What is the electric field induced at a radius r = 1.00 cm from the axis of the solenoid? (Use the following as necessary: t. Let E be measured in millivolts/meter and t be measured in seconds.)
E=?
any help.
Well what have you tried so far to solve these?
Remember Maxwell's equations; they are the tools you'll need to solve most E&M problems at this level. Specifically, Faraday's Law will help with part (a).
can anyone help be out?
hmm apparently my hint wasn't help...
Faraday's law: [tex]E \cdot dl = -\frac{d\Phi}{dt}[/tex]
You know dl, and can calculate the change in flux, so you can solve for E...
im sorry I am still not getting it. can you show me with an example? like use different values or something then i could do it on my own. maybe its just me but that is how i learn.
Faraday says:
[tex]emf = - \frac {d\Phi} {dt}[/tex]
In other words:
[tex]V = - \frac {\Delta B \times A} {\Delta t} = - \frac {\Delta B \times \pi r^2} {\Delta t}[/tex]
Can you apply this formula?
