Separation of Variables for a PDE
The discussion focuses on solving the partial differential equation (PDE) \( u_t + 4tu = u_{xx} \) using the method of separation of variables. The proposed solution takes the form \( u(x,t) = X(x)T(t) \), leading to the eigenvalue problem \( X'' = -\lambda X \) with boundary conditions \( X(0) = 0 \) and \( X(1) = 0 \). The eigenvalues are determined to be \( \beta_n = (n \pi)^2 \) for \( n \in \mathbb{Z}^+ \), resulting in the general series solution \( u(x,t) = \sum_{n=1}^\infty A_n \sin(n\pi x)e^{-k(n\pi)^2 t} \). However, there is uncertainty regarding the treatment of the \( 4tu \) term in the original equation.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with the method of separation of variables
  • Knowledge of eigenvalue problems and boundary conditions
  • Basic concepts of series solutions in mathematical analysis
  • Review the method of separation of variables for PDEs
  • Study eigenvalue problems and their applications in solving differential equations
  • Explore the implications of non-homogeneous terms in PDEs
  • Learn about Fourier series and their role in solving boundary value problems
Mathematics students, educators, and researchers interested in solving partial differential equations, particularly those using separation of variables and eigenvalue analysis.
semithinking
Use separation of variables to find a general series solution of
[tex]u_t + 4tu = u_{xx}[/tex] for [tex]0 < x < 1, t> 0[/tex] and [tex]u(0,t) = u(1,t)=0[/tex].
Looking for a solution of the form [tex]u(x,t) = X(x)T(t)[/tex] implies that [tex]\frac{T'}{kt} - \frac{X''}{X} = 0 \implies \frac{T'}{kT} = \frac{X''}{X} = - \lambda[/tex] where [tex]\lambda[/tex] is a constant.
Then we consider the following eigenvalue problem
[tex]X'' = -\lambda X[/tex] for [tex]0 < x < 1[/tex]
[tex]X(0) = 0 = X(1)[/tex]
If [tex]\lambda = \beta^2 > 0[/tex] then [tex]X(x) = C \cos (\beta x) + D \sin(\sin x)[/tex]. The boundary conditions imply that [tex]C=0[/tex] and [tex]\beta_n = (n \pi)^2[/tex] for [tex]n \in \mathbb{Z}^+[/tex]. All eigenvalues are positive.
Solving [tex]\frac{T'_n}{kT_n} = -\pi^2 n^2 \implies T_n(t) = A_n e^{-k\pi^2 n^2 t}[/tex].
Therefore, [tex]u(x,t) = \sum_{n=1}^\infty A_n \sin (n\pi x) e^{-k(n\pi)^2 t}[/tex] is the general series solution.
BUT! I don't believe this is correct... :P Any corrections?
What did you do with the 4tu term in the original differential equation?
No, it doesn't! Letting u= X(x)T(t) makes the equation
XT'+ 4tXT= X''T. Dividing through by XT,
[tex]\frac{T'}{T}+ 4t= \frac{X''}{X}= -\lambda[/tex]
so we have
[tex]X''+ \lambda X= 0[/itex]<br /> and <br /> [tex]T'+ 4tT= \lambda T[/tex]<br /> or <br /> [tex]T'= (\lambda- 4t)T[/tex]<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Then we consider the following eigenvalue problem <br /> [tex]X'' = -\lambda X[/tex] for [tex]0 < x < 1[/tex]<br /> [tex]X(0) = 0 = X(1)[/tex]<br /> <br /> If [tex]\lambda = \beta^2 > 0[/tex] then [tex]X(x) = C \cos (\beta x) + D \sin(\sin x)[/tex]. The boundary conditions imply that [tex]C=0[/tex] and [tex]\beta_n = (n \pi)^2[/tex] for [tex]n \in \mathbb{Z}^+[/tex]. All eigenvalues are positive.<br /> <br /> Solving [tex]\frac{T'_n}{kT_n} = -\pi^2 n^2 \implies T_n(t) = A_n e^{-k\pi^2 n^2 t}[/tex].<br /> <br /> Therefore, [tex]u(x,t) = \sum_{n=1}^\infty A_n \sin (n\pi x) e^{-k(n\pi)^2 t}[/tex] is the general series solution.<br /> <br /> BUT! I don't believe this is correct... :P Any corrections? </div> </div> </blockquote>[/tex]
