Determining Electric Charge of a Bullet in Earth's Magnetic Field
The discussion focuses on calculating the electric charge of a bullet fired in Earth's magnetic field, which has a magnitude of 5.30e-5 T directed north at a 57° angle below the horizontal. The bullet, moving at a speed of 681 m/s and at an angle of 11° above the horizontal, experiences a magnetic force of 2.90e-10 N directed due east. The formula used for the calculation is q = f / (vBsin(theta)), leading to a calculated charge of -9e-9 C. The participant expresses uncertainty about the correctness of their answer, suspecting a mistake in their approach.
  • Understanding of magnetic fields and forces
  • Familiarity with the right-hand rule for determining force direction
  • Knowledge of vector components in physics
  • Proficiency in using trigonometric functions, specifically sine
  • Review the right-hand rule and its application in electromagnetism
  • Study vector decomposition in the context of forces and angles
  • Learn about the Lorentz force equation and its components
  • Explore examples of electric charge calculations in magnetic fields
Students in physics, particularly those studying electromagnetism, as well as educators seeking to clarify concepts related to magnetic forces and electric charge calculations.
cclement524
1. Homework Statement
In a certain region, the Earth's magnetic field has a magnitude of 5.30e-5 T and is directed north at an angle of 57° below the horizontal. An electrically charged bullet is fired north and 11° above the horizontal, with a speed of 681 m/s. The magnetic force on the bullet is 2.90e-10 N, directed due east. Determine the bullet's electric charge, including its algebraic sign (+ or −).
2. Homework Equations
q = f / vBsin(theta)
3. The Attempt at a Solution
q = 2.90e-10 N / (681)(5.30e-5)(sin 11+57)
-9e-9
My answer is negative according to the right hand rule.
I'm wrong, but I don't know where I went wrong. If you could help me I would greatly appreciate it. Thank you!
Even I think its negative. The book's answer seems wrong.
  • · Replies 16 ·
