Parallel or inline for most cfm
  • Thread starter Thread starter sack98
    Cfm Parallel
The discussion revolves around the design of a blower system using multiple motors, specifically comparing the effectiveness of parallel versus inline configurations for maximizing airflow (cfm). The context includes practical applications in building a livestock blow dryer and considerations of pressure and duct sizing.
  • One participant suggests that using four motors in parallel could potentially yield a higher combined airflow at a specific discharge pressure compared to two inline motors.
  • Another participant notes that for centrifugal pumps or blowers in parallel, the flows can be summed at a given pump head, providing a theoretical combined output of 488 scfm at the same pressure.
  • There is a consideration of the duct system size, with one participant indicating that a larger duct would be necessary to accommodate the combined flow from multiple motors.
  • One participant expresses uncertainty about the pressure at which the blowers generate the rated 122 cfm, seeking clarification on this aspect.
  • A participant describes their specific setup and proposes modifications, including the idea of funneling the output from four parallel motors into a larger pipe, while questioning the impact of pipe length on performance.
Participants express differing views on the optimal configuration for the blower system, with no consensus reached on whether parallel or inline setups would be more effective. The discussion remains unresolved regarding the best approach to maximize airflow and pressure.
Participants mention assumptions about duct sizes and pressures, as well as the practical constraints of building a portable system. The impact of pipe length on performance is also raised but not fully explored.
sack98
I'm building a blower system with 4, 5.7 inch thu-flow motors they are 122 cfm @ 2" orfice with 2 stage blower. When I build the system will they have more cfm building the system with 4 parallel motors dumping into a funnel or y piping 2 inline systems?
For centrifugal pumps/blowers in parallel, the flows add at a particular pump head (discharge pressure). For example, if each blower is rated 122 scfm at 20 inwc, the combined head of four in parallel would be 488 scfm @ 20 inwc.
...and that assumes a duct system with twice the size.
Sorry this will be to build pressure out going port is 2 inch
Ok what I am building is a livestock blow dryer they want a little over a grand to buy it I think i can build it for half that. So its basically 4 5.7 inch thru flow motor(industrial vacuum motors reversed) necked down to a 2 inch pipe. current setups are 2 inline motors funneled to a 1.5 inch pipe that are connected to a y pipe that is 2 inch out let. I could build this but if I am going to build it I was wanting to try to improve it I was thinking 4 parellel motors funneling to 1.5 inch pipe then those 4 dumping into maybe a 4 inch funnel that goes to 2 inch. don't know if it would help or just a waste of a lot of time. also one other question will length of pipe matter much or not It has to be portable so the closer together I can keep everything the better.
  • · Replies 22 ·
  • · Replies 19 ·
13K
11K
