noexit1982
- 1
If an object moving at a constant speed be launched into orbit? Irregardless of what that speed is and time not being a factor.
The discussion centers around the conditions under which an object moving at a constant speed can be launched into orbit. Participants explore the implications of constant speed, gravitational forces, and atmospheric effects on the object's trajectory.
Participants express differing views on the relationship between constant speed and the ability to achieve orbit, with no consensus reached on the conditions necessary for orbital insertion.
The discussion includes assumptions about gravitational forces, atmospheric conditions, and the effects of propulsion, which remain unresolved and may influence the conclusions drawn.
Actually, since the force of gravity is inversely proportional to the distance r between the center of the Earth and the object, and since the density of the atmosphere also decreases as the distance from Earth increases, a decreasing force will propel an object at a constant speed.A constant speed requires a constant force to push the object. However, gravity is pulling the object down at a constant acceleration of 9.8m/s^2, and of course air resistance.
That's the speed an object must have at (or very close to) the surface of the earth in order to escape Earth's gravitational pull, assuming that no force other than gravity (i.e. no air resistance, no propulsion) acts on the object after it has reached that speed.The minimum speed to get an object out of the Earth's atmosphere is around 11km/s, according to 0.5mv^2 = GmM/R.
