| New Reply |
Pressure drop in pipe due to bends and/or pressure reducing valves ? |
Share Thread | Thread Tools |
| Mar21-11, 05:25 AM | #1 |
I am currently doing my final year project and have a few queries. I would be really grateful if someone could answer the following questions for me as soon as possible.
• The requirement is to drop the pressure from 140-150 bars at the inlet of a pipe to 2 bars at the outlet of the pipe. • The pressure of 2 bars is to be maintained at the outlet of pipe. • The pipe length is 1-2 metres long. • Pipe is made of copper or a copper alloy. • The pressurized gas used is Nitrogen. • The pipe diameter is not fixed yet and can be varied (but is to be kept as small as possible). Please answer the following questions for me: • Can the pressure drop be achieved using only bends in the pipe? • Would using a pressure reducing valve be a better option? • Or should both of the above options be considered? • For any option chosen please let me know the calculations involved. The unknown variables can be assumed over a standard range. Thanking you, Anshuman |
| Mar26-11, 03:14 PM | #2 |
If you have enough money in the project, a "back pressure regulator" is your best choice.
Fisher and Jordan make industrial strength regulators. You may be able to find something cheaper if you need. |
| New Reply |
| Tags |
| bends, pipes, pressure drop, valves |
| Thread Tools | |
Similar Threads for: Pressure drop in pipe due to bends and/or pressure reducing valves ?
| pressure drop in elbows & bends in a pipe | Mechanical Engineering | 17 | ||
| Pressure drop expansion valves | Mechanical Engineering | 1 | ||
| Pressure drop across valves | Mechanical Engineering | 5 | ||
| Static pressure in round pipe bends do what? | General Physics | 0 | ||
| Calculating Pressure Drop across radiators and valves? | Engineering, Comp Sci, & Technology Homework | 0 | ||
