New Reply
Component vector method for resultant force
Share Thread Thread Tools
Mar24-11, 05:39 PM   #1
An object has two ropes attached. One is on the x axis (positive) with a 60 lb force. One is 120* (Quadrant II) from the first rope with a 30 lb force. I have to find the resultant force and angle using the component vector method of addition NOT the parallelogram method.
2. Relevant equations
Fa + Fb = R
3. The attempt at a solution
I set up a table of components, but I am not sure if they are correct. I am just really confused as to how to approach this problem. I know how to do it using the parallelogram method, but it seems like some important piece of information is missing for doing it using the component vector method.
A=30 lb
B= 60 lb
Angle A=120*
Angle B=0*
Ax = ??
Bx = 60 lb
Ay = ??
By = 0
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Mar25-11, 06:06 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi argentnox! welcome to pf!
(try using the X2 icon just above the Reply box )
to find the component in a direction, always multiply by cos of the angle to that direction
Mar25-11, 12:49 PM   #3
Thank you, I will try that and see how I do. If it is okay, I will probably come back to make sure I got the correct answer. I figure if I got the answer correct, I must have done the work correctly. ;)
New Reply
Thread Tools
Similar Threads for: Component vector method for resultant force
Thread Forum Replies
Resultant component of adding Three simple harmonic motions together help...Diagram! Introductory Physics Homework 3
vector addition analytical & component method Introductory Physics Homework 2
Finding resultant force/vector help? Introductory Physics Homework 1
Help with adding vectors with component method (sin/cos/tan) Introductory Physics Homework 3
Vector addition problem - component method Introductory Physics Homework 15
