Thread Closed
Fusion Reactors
Share Thread Thread Tools
Oct18-04, 05:44 AM   #1
Fusion Reactors
How far is research really gone? Is there any major breakthrough on its way? Are the first prototypes ready yet?
I'm making a project work on this for school, and I find it hard to find sufficient information in books and likes about this, since clearly, books from the beginning of the last decade are going to be very out-of-date today...
I gathered from the Cold Fusion thread, that Cold Fusion is not even an option as it's not do-able?
What are the major obstacles with a fusion reactor as of today? And are there any realistic plans to overcome these obstacles? How far is the research gone in the USA (this is also hard for me to find out since I'm situated in Sweden and mostly can gather info about the JET project)...
ITER is a cooperative effort between Japan, USA and Europe, am I right?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Oct18-04, 09:32 AM   #2
Recognitions:
Quote by shingetsunohimitsu
shingetsunohimitsu,
First Cold Fusion was a fraud - a couple chemists went public with some
work they didn't understand - and the physics community agrees that
cold fusion never did exist.
Controlled thermonuclear fusion is incredibily difficult - research has
been underway for decades. There are two main approaches - magnetic
confinement and inertial confinement.
Magnetic confinement is the attempt to contain the reaction a magnetic
"bottle". Tokamaks are the leading type of magnetic fusion machine.
That said, the USA has not built a tokamak in years. The leading machine
was the TFTR - Tokamak Fusion Test Reactor at Princeton University's
Plasma Physics Center.
The ITER would follow the work of TFTR - but it has been under discussion
for over a decade - and nothing has actually been built.
In the are of inertial confinemet fusion - i.e. "laser fusion" research is
continuing at the Omega Laser at the University of Rochester. The NIF -
the National Ignition Facility at Lawrence Livermore is in the process
of bringing up the lasers. The physical facility has been built - and will
eventually have 192 laser chains. About 8 laser chains are now operating:
http://www.llnl.gov/nif/project/index.html
http://www.llnl.gov/nif/project/lib_construction.html
http://www.llnl.gov/nif/project/lib_highlights.html
The NIF will be the first machine to achieve "ignition" - that is to
generate as much energy from fusion as was put into the fusion fuel.
However, that's a long, long way from generating large amounts of
power.
Dr. Gregory Greenman
Physicist LLNL
Oct18-04, 05:29 PM   #3
If you view ITERs website http://www.iter.org, somewhere on there is a timeline. I believe that they are expecting their experimental reactor to come online somewhere around 2010 so that commerically viable plants can be built later on.
The United States dropped out of ITER for a while (political reasons) and rejoined last year along with China and Korea.
Oct18-04, 06:23 PM   #4
Recognitions:
Homework Helper Homework Help
Fusion Reactors
There are non-mainstream reactor designs. For example fusors (http://www.fusor.net/) which are not likely to ever produce net energy and sonoluminescent reactors (sorry, no link).
Oct19-04, 10:48 AM   #5
I recently had the opportunity to visit Omega. The first major obstacle is to maintain the large temperature that is needed to make a reaction. With inertial confinement, it lasts for nanoseconds (a short laser pulse). A bit more (milliseconds?) is achieved with tokamaks. NIF will do an important step by reaching a break-even point.
It is important to note that these systems are also used by astrophysicists to simulate star core physics, they are not just pre-pre-... - reactor prototypes.
Oct19-04, 02:06 PM   #6
Recognitions:
Gold Membership Gold Member
I suppose the ITER project is lagging a bit due to the member countries bickering about the location of the next stage experimental reactor, which I think ought to be a major improvement over the previous ones and pave the way for "commercial" ones (with any luck).
Oct25-04, 02:02 AM   #7
Fusion is too dangerous and has been killed. If you have a good fusion system you are able to transmute to produce any end product you wish. As you can guess that can be very dangerous.
The best fusion results to date have been the predecessor of the proposed X-1 project
http://www.sandia.gov/media/Z.htm
This has dropped of the scope and I don’t think you will find anymore about results.
Oct25-04, 09:25 AM   #8
Quote by 4newton
Who said this and when? And what about fusion of iron and heavier atoms which are endothermic fusion reactions? In theory those elemnts could be fused but how would any man made machine be able to produce that much energy if even stars implode when fusing iron?
Oct25-04, 03:49 PM   #9
Recognitions:
The only practical fusion reactors are those converting isotopes of hydrogen to helium. Anything else would involve much higher temperatures and pressures and would be impossible today on any useful scale.
Oct25-04, 05:17 PM   #10
Exactly, mathman. Being able to produce any end product you could want would require being able to do H to He and get net energy from it, to continue fusion. Producing Plutonium or Uranium from just Hydrogen would still be a long ways off even if we could.
Nov2-04, 02:46 PM   #11
Recognitions:
Quote by theCandyman
Candyman,
Exactly - producing Plutonium and Uranium is best left to supernovae.
You get the minimum binding energy per nucleon with Iron.
If you fuse elements lighter than Iron - you get energy.
If you fission elements heavier than Iron - you get energy.
Physicist
Nov29-04, 10:30 PM   #12
I'm hedging my bets on saltwater. Hot fusion seems to be our only road forward. I'm still undecided as to whether I should study magnetic confinement or inertial/laser systems though. My gut says "magnetics", but laser-type systems have become more viable. Is this correct? This is my first year in college, and I do have to choose a suitable university in Ca.
Nov29-04, 11:29 PM   #13
Admin
Savitri, the University of California has very good engineering programs at the San Diego (UCSD), Santa Barbara (UCSB) and LA (UCLA) campuses. And there is also UC Berkeley, which still has a nuclear engineering program.
In addition, General Atomic is located there in San Diego.
Nov30-04, 12:33 AM   #14
Thanks Astronuc.
Nov30-04, 12:53 PM   #15
Ok, this thread is a bit old (has been dormant for about a month until yesterday), but if anyone is still interested, goolge for "fusion ignition research experiment", aka FIRE (unforetunately, googling for "fire" gives too many irrelevant results, so you have to use the full name).
Dec3-04, 01:58 PM   #16
Recognitions:
Heard today that the location of ITER might finally be set ... France ... I've been out of the loop for a while, anyone got any other information on this or is this just a scoop ?
Nov27-05, 03:18 PM   #17
What happens if you replace the NIF lasers with say electrons with the proper energy to create x-rays in a closed high-Z chamber?
Thread Closed
Thread Tools
Similar Threads for: Fusion Reactors
Thread Forum Replies
Questions on reactors and VASIMR Nuclear Engineering 14
Saturable reactors Electrical Engineering 1
Passive Reactors. Nuclear Engineering 17
Focus Fusion Reactors Nuclear Engineering 1
Critique; Fusion Reactors Introductory Physics Homework 1
