How Can I Convert a Variable DC to an AC Inverter for Off-Grid Use?
The discussion focuses on converting a Jacobs wind turbine controller, originally designed for grid-tie applications, into an off-grid inverter. The goal is to create a Variable DC input inverter that outputs a pure sine wave at 120/240 VAC split phase. The existing setup includes a 3-phase "wild" AC input that is rectified to variable DC (40-180 volts). A simple signal generator capable of producing a 60 Hz reference waveform is recommended as a solution, with options available on platforms like eBay and Amazon.
  • Understanding of inverter design principles
  • Knowledge of variable DC to AC conversion techniques
  • Familiarity with sine wave generation
  • Experience with wind turbine systems and controllers
  • Research signal generator options for 60 Hz waveform production
  • Explore designs for Variable DC input inverters
  • Investigate components for pure sine wave output
  • Learn about off-grid power systems and their requirements
This discussion is beneficial for electrical engineers, renewable energy enthusiasts, and DIY hobbyists interested in off-grid power solutions and inverter technology.
Nbrooks
So here is what I am trying to accomplish. I am trying to take an old Jacobs wind turbine controller that was designed for a grid tie application and make it off grid. There is a 3 phase "wild" ac input from the turbine that is rectifyed but not clipped by the internal SCR's to variable DC (40-180 volts). The sensing was designed to tie to the grid and power sync'd to line power and freq then exported or imported depending on demand.
What I would like to do is build a Variable Dc input inverter that will put out a pure sine wave 120/240 vac split phase. Thus imprinting a usable power output and allowing the cap/choke inverter portion of the controller to do its part. The design need not handle much power as it is only used as an imprint to regulate the power through the controller.
If anyone had any idea on a build for this or a manufacturer that is producing such an item I could really use some ideas.
Thanks
You just need a simple singnal generator that can make a 60 Hz reference waveform. You can find them on Ebay and Amazon
  • · Replies 84 ·
19K
