Solving Spring Confusion: Ee2 Canceled Out or Not?
  • Context: Undergrad
  • Thread starter Thread starter FarisL
    Confusion Spring
The discussion revolves around a physics quiz question involving a mass-spring system where two masses are placed on a spring, and one mass is suddenly removed. Participants explore the implications of energy conservation and the behavior of the spring to determine whether the elastic potential energy (Ee2) is canceled out in the calculations for maximum height reached by the platform.
  • One participant states that Ee2 is canceled out, leading to a maximum height calculation of around 1.1 m.
  • Another participant argues that Ee2 should not be canceled out, using the example of a very small mass to illustrate that not all energy is converted to gravitational potential energy.
  • There is a claim that for a system to reach maximum height, all energy must be gravitational potential energy, which contradicts the previous point about elastic potential energy.
  • A participant clarifies that when the velocity is zero, energy can be in forms other than gravitational potential energy, citing a mass on a spring vibrating horizontally as an example.
  • One participant mentions their teacher's belief that all energy but gravitational energy is canceled out, indicating a potential misunderstanding or differing interpretation of the problem.
  • Another participant proposes analyzing the forces and equations of motion, providing a detailed mathematical approach to determine the maximum height based on the dynamics of the system.
  • There is a discussion about the meaning of variables used in the equations, specifically the spring stiffness denoted as D or K.
  • A later reply suggests that the teacher's explanation may not align with the assumptions made in the mathematical analysis, particularly regarding whether the masses are fastened to the platform or simply resting on it.
Participants express differing views on whether Ee2 is canceled out in the energy conservation equation, leading to unresolved debate. Some participants support the idea that energy can exist in forms other than gravitational potential energy, while others maintain that it must all convert to gravitational potential energy for maximum height. The discussion remains unresolved with multiple competing views.
Participants reference different assumptions regarding the conditions of the masses on the platform and the nature of energy transformations in the system, which may affect the conclusions drawn. There is also a lack of consensus on the interpretation of the teacher's explanation and its implications for the problem.
FarisL
So I got this question on a physics quiz:
"You have have two masses, M1 and M2, weighing 1.00 kg and 2.00 kg respectively. You have an ideal, massless spring (spring constant = 40.0 N/m) set up vertically from the ground with a massless platform attached to its free end on top. The two masses are gently placed on top of each other on the platform, so that the mass-spring system is at rest, with the platform's height set as zero relative to the system (for simpler calculations). Suddenly, the 2.00 kg mass is removed, causing the system to rebound vertically upwards. Find the maximum height the platform reaches."
You are first required to find the distance, x, the spring contracts when the two masses are placed on it, using kx = mg. Once you know that, you are to find the maximum height using the equation for the conservation of energy, Ek1+Eg1+Ee1 = Ek2+Eg2+Ee2, where Ek is the kinetic energy, Eg is the gravitational energy, and Ee is the elastic energy.
Now, both Ek1 and Ek2 are canceled out, as they equal zero. Eg1 is canceled out as well, as the height at that moment is zero as well. We are left with Ee1 = Eg2+Ee2.
My question: Is Ee2 canceled out or not?
I solved it using the two scenarios; if it is, you should get an answer of around 1.1 m. If not, you should get something like 0.981 m.
No. Think what would happen if M2 was very small (say 1 gram). The spring would rebound a small distance, but not far enough to release all its strain energy.
But then there's the argument that, for a system to reach its maximum height, all the energy must be concentrated as gravitational potential energy. In order to do that, both kinetic and elastic energy must equal zero, according to the law of conservation of energy; hence Ee2 is canceled out.
That's why I'm confused. To me, the concepts seem to contradict each other.
That is not correct. When the velocity is zero, all the energy must be in some form of potential energy, but there is no reason why it must all be gravitational potential energy.
Think about a mass on a spring vibrating horizontally. There is no change in gravitational PE. The energy is transferred from all kinetic energy when the spring is at its unstretched length, to all elastic potential energy when spring is at its maximum length and the velocity is zero.
Thing is, like I said before, this came up on my quiz. My teacher firmly believes that everything but the gravitational energy is canceled out, since if you were to look at it from a mathematical view of point, the height would end up maximum. Though your reasoning makes perfect sense. I'll have to ask him once more.
Thank you for your replies
I'd rather analyze the forces and solve the equations of motion.
First, when both masses are sitting on the spring, we have given, that the whole thing is at rest, i.e., the forces are [tex]0[/tex]. Let [tex]x=0[/tex] be the end of the spring, if there's no mass on it. Now, with both masses sitting on the spring, this end is at [tex]x=x_0<0[/tex]. Vanishing of the total force on these masses says:
[tex]-D x_0-(M_1+M_2)g=0 \; \Rightarrow \; x_0=-\frac{(M_1+M_2)g}{D}[/tex]
When now the mass, [tex]M_2[/tex], is taken suddenly away, we have the initial condition for the remaining mass [tex]M_1[/tex]:
[tex]x(0)=x_0, \quad \dot{x}(0)=0[/tex].
Now the equation of motion reads
[tex]M_1 \ddot{x}=-D x-M_1 g[/tex]
The general solution of this equation is
[tex]x(t)=A \cos(\omega t)+B \sin(\omega t)-\frac{M_1 g}{D}[/tex]
with [tex]\omega=\sqrt{D/M_1}[/tex].
With the initial conditions, we get
[tex]x(t)=\left (x_0+\frac{M_1 g}{D} \right ) \cos(\omega t)-\frac{M_1 g}{D}[/tex]
or
[tex]x(t)=-\frac{M_2 g}{D} \cos(\omega t)-\frac{M_1 g}{D}[/tex]
The maximum height is reached for [tex]\cos(\omega t)=-1[/tex], i.e., at [tex]t=T/2=\frac{\pi}{\omega}[/tex]. The height obviously is
[tex]x_{\text{max}}=\frac{(M_2-M_1) g}{D}[/tex].
Wait, what does D represent?
In the other post D is the spring stiffness. English math books usually use K.
You can see the previous answer is right by a simpler argument.
With both masses on the spring, the equilibrium position is
[tex]x_0 = -(M_1 + M_2)g/K[/tex]
With one mass on the spring, the equilibrium position is
[tex]x_1 = -M_1g/K[/tex]
If you release the spring at [itex]x_0[/itex] and its equilibrium position is [itex]x_1[/itex], it will do simple harmonic motion about [itex]x_1[/itex] with amplitude [itex]x_0-x_1[/itex].
So the highest and lowest points of the motion must be [itex]x_1 - (x_0-x_1)[/itex] and [itex]x_1 + (x_0-x_1)[/itex], or [itex]x_0[/itex] and [itex]2x_1-x_0[/itex].
[tex]2x_1 - x_0 = -(M_1 - M_2)g/K[/tex]
Ahhhh...
I think I see what your teacher is saying now, but I don't like his explanation for it.
The math in posts #6 and #8 assumes that the masses are fastened to the platform, not just resting on it. With that assumption it is possible for the maximum height to be above the unstretched length of the spriing, depending on the values of M1 and M2. This would happen for the values of M1 and M2 in your OP.
When the platform is above the unstretched length of the spring, the spring is pulling down on the mass, but the inertia of the mass and its upwards velocity mean it will rise to a higher position before it stops.
But in the question the mass is not fastened to the platform, it is resting on it. So when spring reaches its unstretched length, the platform will stop moving upwards and the mass will leave the platform and move higher.
This is not about energy, it is about the fact that the force between the platform and the mass can only act one way.
As I said before, if M2 is small compared with M1, the platform will not return to its original position. The math agrees with that statement.
  • · Replies 24 ·
  • · Replies 76 ·
  • · Replies 17 ·
