Why dummy variables used for the coefficients of a PDE solution?
The discussion revolves around the use of dummy variables in the context of solving partial differential equations (PDEs) using separation of variables, particularly in relation to the heat equation. Participants are exploring the implications of using dummy variables when determining coefficients in a Fourier series representation of the solution.
  • Conceptual clarification, Mathematical reasoning
  • Participants discuss the general form of solutions to PDEs and the role of boundary conditions in determining coefficients. Questions arise regarding the necessity and purpose of using dummy variables, such as t^bar or x_bar, in the context of integrating to find coefficients.
Some participants have provided insights into the use of different variables to avoid confusion and clarify the scope of integration. There is an ongoing exploration of the reasoning behind this practice, with no explicit consensus reached on the necessity of dummy variables.
Participants note that the details of the equations and boundary conditions may not be precisely correct, but they emphasize that this does not detract from the core question regarding the use of dummy variables.
AStaunton
have been solving PDEs by sep of variables, and the solution that comes out is generally a summation the general look of it is something like:
U=SIGMA(n=1 to infinity)E_n(sin(n(pi)x/L)(cos(n)(pi)x/L)t
The above may not be exactly right, I was thinking along the lines of heat equation where U=temperature x=position and t=time..in most of the basic probs I am doing, a boundary condition is given something like U=f(t) at x=0 or something like that...and this BC is used to solve for E_n...
My question is why when we solve for what the E_n's are do we then use dummy variables to express it...in this case the dummy variable would by t^bar...
The details of what I've written above aren't correct I know, but I hope that that doesn't matter in terms of the question I am asking..
More likely U(x,0) = f(x), which I will use...
So you would likely have something like
[tex]f(x) = \sum_{n=0}^{\infty}E_n\sin(n\pi x/L) \cdot 1[/tex]
I'm not sure what dummy variable you refer to. At this point you have a simple Fourier series expansion for f(x) and the En are the Fourier coefficients. Are you referring to the dummy variable inside the integral for the coefficient En? En is just a constant...
yes, sorry I was unclear.
when we solve for E_n and plug into the final eigenfunction, we use x_bar (or some other variable) instead of x...
it has not been clear to my why this has to be done:
[tex]E_{n}=\frac{2}{L}\int_{0}^{L}f(\bar{x})\sin(\frac{n\pi\bar{x}}{L})d\bar{x}[/tex]
The dummy variable does not matter. It helps to use a different one for two reasons. It reminds us not to use it ourside the integral and avoids confusion with the our main variable.
  • · Replies 16 ·
