PIC Microcontrollers: Q1 & Q2 Solutions
  • Thread starter Thread starter Frisky90
This discussion focuses on programming the PIC16F917A microcontroller to control LEDs using C language. The user seeks to write a program that outputs binary equivalents of decimal numbers 119, 76, 14, 55, and 99 on port D. Additionally, the user inquires about using a switch to toggle odd-numbered LEDs based on the status of bit 0 of port A. The discussion emphasizes the need for specific C syntax for reading and writing to ports and differentiating between decimal and hexadecimal number representations.
  • Understanding of PIC16F917A microcontroller architecture
  • Basic knowledge of C programming language
  • Familiarity with binary and hexadecimal number systems
  • Experience with microcontroller I/O port operations
  • Research PIC16F917A I/O port programming in C
  • Learn about binary and hexadecimal number conversions in C
  • Explore switch input handling in embedded C programming
  • Study examples of LED control using PIC microcontrollers
Embedded systems developers, electronics engineers, and students learning microcontroller programming, particularly those working with PIC microcontrollers and C language.
Frisky90
My question is related to PIC Microcontrollers.
Q 1
I have to use port D of the PIC16F917A as an output port and write a simple program to control 8 LEDS to generate the binary-equivalent of the following decimal numbers:
119, 76, 14, 55 & 99
I know how to convert the numbers, but I am not that familiar with the C language.
Q 2
Use a switch as an input to read the status of bit 0 of port A, write a program to switch all odd numbered LEDs (the most right hand LED is number 0) connected to port D, upon detecting the switch closure.
Q 1
Q 2
Could you show the syntax for reading and writing from those ports via C for the PIC?
Also, in C, you can specify if the number is decimal or Hexidecimal? Can you check your C book to see if you can find the syntax to use for the two different base designations?
  • Sticky
9K
  • · Replies 97 ·
24K
