Fully Developed Flow between two parallel plates
The discussion focuses on solving a fluid dynamics problem involving fully developed flow between two parallel plates, where one plate experiences a constant heat flux and the other is insulated. The velocity profile is defined as U=2*Uinf*(1-r^2/h^2), with h representing the radius. Participants emphasize starting with the governing equations and applying boundary conditions, specifically noting that the insulated plate results in a zero heat flux condition. The solution involves simplifying the equations to focus on the diffusion term perpendicular to the plates, as both velocity and temperature are fully developed.
  • Understanding of fluid dynamics principles, particularly fully developed flow.
  • Familiarity with heat transfer concepts, including constant heat flux and insulation effects.
  • Knowledge of differential equations and boundary condition applications.
  • Experience with velocity profiles in fluid mechanics.
  • Study the governing equations for heat transfer in parallel plate systems.
  • Learn about the implications of boundary conditions on temperature distributions.
  • Research the effects of viscous dissipation in fluid flow problems.
  • Explore numerical methods for solving differential equations in fluid dynamics.
This discussion is beneficial for students and professionals in fluid dynamics, thermal engineering, and mechanical engineering, particularly those dealing with heat transfer and flow analysis in parallel plate configurations.
JasonB_VT
Hey you all,
I have a practice exam problem which is causing some difficulty for me.
Basically I have a fully developed flow through two parallel plates. One plate has a constant heat flux and the other plate is heavily insulated.
I have found the velocity profile: U=2*Uinf*(1-r^2/h^2)
where h is the radius.
Now I have set up the boundary condition to solve the differential equation but I'm confused on which equation to use. There is a general equation (I would post it here but its too messy) that will solve temperature distributions in a tube. With these equations, however, there is either a constant temperature or constant flux around the whole boundary.
I am confused on how to go about solving this problem, any advice will help! Thank you.
You can basically start with governing equations. Start canceling out terms until you're left with a differential equation that you can solve.
For example, you can show that radial velocity = 0; you know that d/dz = 0 as well.
Like minger mentioned start with the governing equation and then apply the boundary conditions. Which in your case would be constant heat flux at both boundaries. Heavily insulated means no heat flux which is a constant heat flux of 0.
If the flow is fully developed for both velocity and temperature between two plates you should only be left with the diffusion term perpendicular to the plates because there is no temperature gradient in the flow direction and no velocity component perpendicular to the plates. The only other thing to consider would be viscous dissipation but I guess it depends on the situation whether or not you want to keep that term.
  • · Replies 30 ·
  • · Replies 167 ·
39K
  • · Replies 31 ·
  • · Replies 26 ·
