Help with flow speed & Thermodynamics
This discussion addresses two thermodynamic problems: calculating the necessary flow speed in a duct and determining the energy required to heat a volume of air. For the duct, the necessary flow speed is calculated to be 95.5 meters per minute, derived from the volume exchange requirement of a room measuring 3m x 4.5m x 6m every 12 minutes. The second problem involves calculating the energy needed to raise the temperature of 100 m³ of air at 300K by 2 degrees Celsius, utilizing the heat capacity formula with Cp = 7R/2.
  • Understanding of fluid dynamics, specifically flow rate calculations.
  • Familiarity with thermodynamic principles, including heat capacity and the ideal gas law.
  • Knowledge of basic geometry for calculating cross-sectional areas of circular ducts.
  • Ability to perform unit conversions, particularly between minutes and seconds.
  • Study the application of the ideal gas law in different thermodynamic scenarios.
  • Learn about the principles of heat transfer and energy calculations in thermodynamics.
  • Explore advanced fluid dynamics concepts, including laminar and turbulent flow.
  • Investigate the effects of insulation on energy efficiency in HVAC systems.
Engineers, HVAC professionals, and students in thermodynamics or fluid mechanics who are looking to deepen their understanding of airflow calculations and energy requirements in heating systems.
mickeychief
I have 2 questions that I need help with:
1. a room measures 3m by 4.5m by 6m. The heating and air conditioning ducts to and from the room are cicular witha a diameter of 0.30m, and the air in the room is to be exchanged every 12 minutes. What is the necessary flow speed in the duct? (assume that the disity of the airs is constant)
2. A house has well-insulated walls. It contains a volume of 100 m^3 of air at 300K. Calculate the energy ot increase the temperature of this diatomic gas by 2 degrees C. Assume it is heating at a constant pressure and use Cp=7R/2.
For the first problem, the air ducts must remove (and replenish) a volume of air given by 3m x 4.5m x 6m in 12 min. Thus the mass flow rate of the system is given by
[tex]\frac{dm}{dt} = \rho \frac{dV}{dt} = \frac{\rho_{air} V}{t} = \rho_{air} \frac{3\cdot 4.5\cdot 6 \ meters^3}{12 \ min}[/tex]
Of course you'll have to convert minuntes to seconds to get a flow rate of kg/s. You can use the same formula to calculate the flow speed in the air duct like so.
[tex]\frac{dm}{dt} = \rho \frac{d(AL)}{dt} = \rho A \frac{dL}{dt} = \rho A v[/tex]
Here, A is the cross sectional area of the pipe and v is the velocity that you're looking for.
For the second problem use
[tex]C_p = \frac{7}{2} nR = \frac{\partial U}{\partial T}[/tex]
Here, n is the number of moles of the gas (you can determine this from the ideal gas law) and C_p is the HEAT CAPACITY (not specific heat) at constant pressure.
Sure, I would be happy to help with your questions about flow speed and thermodynamics.
1. To calculate the necessary flow speed in the duct, we can use the formula Q = AV, where Q is the volume flow rate, A is the cross-sectional area of the duct, and V is the flow speed. We know that the volume of air in the room needs to be exchanged every 12 minutes, so we can calculate the volume flow rate as follows:
Q = (3m x 4.5m x 6m) / 12 minutes = 6.75 m^3/min
Next, we can calculate the cross-sectional area of the duct using the formula A = πr^2, where r is the radius (diameter/2) of the circular duct.
A = π(0.30m/2)^2 = 0.0707 m^2
Now, we can plug in these values into the formula Q = AV to solve for V:
6.75 m^3/min = (0.0707 m^2) x V
V = 95.5 m/min
Therefore, the necessary flow speed in the duct is 95.5 meters per minute.
2. To calculate the energy required to increase the temperature of the air in the house, we can use the formula Q = mcΔT, where Q is the energy, m is the mass of the air, c is the specific heat capacity, and ΔT is the change in temperature.
First, we need to calculate the mass of the air using the ideal gas law: PV = nRT, where P is the pressure, V is the volume, n is the number of moles, R is the gas constant, and T is the temperature. We know that the volume of air is 100 m^3 and the temperature is 300K, so we can rearrange the formula to solve for n:
n = (PV) / (RT) = (1 atm x 100 m^3) / (0.0821 L atm/mol K x 300K) = 4.06 moles
Next, we can calculate the mass of the air using the molar mass of diatomic gas (28.97 g/mol):
m = n x molar mass = 4.06 moles x 28.97 g/mol = 117.7 g
Now, we can plug in
  • · Replies 24 ·
