Understand Hooke's Law and Spring Dynamics
The discussion revolves around understanding Hooke's Law and the dynamics of springs, particularly in scenarios involving objects in motion, such as a ball bouncing and compressing a spring. Participants explore the effects of gravity on spring compression and the time it takes for an object to compress a spring after impact.
  • One participant questions how to determine the time it takes for an object to compress a spring when the force and acceleration are changing, given an initial velocity and spring constant.
  • Another suggests that the motion becomes simple harmonic after the object hits the spring and recommends using methods of simple harmonic motion (SHM) to find the time taken.
  • A participant raises a scenario where an object hits a spring out of phase after being pulled down by gravity, questioning whether the work done by the spring needs to be considered in this case.
  • There is a reiteration that the compression of the spring will differ when the object is bouncing vertically due to the influence of gravitational potential energy, contrasting it with horizontal motion where gravity does not contribute.
  • One participant provides a mathematical approach to model the spring compression using a differential equation, concluding that the time to full compression depends on the mass and spring constant, not the initial velocity.
Participants express differing views on the effects of gravity on spring compression and the time it takes for compression. There is no consensus on the best approach to determine the time of compression or the implications of different motion scenarios.
Participants mention various assumptions regarding the initial conditions and the influence of gravitational potential energy, indicating that the discussion may depend on specific definitions and scenarios not fully resolved within the thread.
daveed
allright, here is something i haven't been able to understand with just hooke's law
if i have an object traveling at velocity v, let's say, 4m/s , and hits a spring at, i don't know, k=2? so then we know how far the spring compresses and all because you just need to set the work done and kinetic energy equal, but what i have not been able to get is how long does it take for it to compress? because with a changing force(and so a changing acceleration), i don't understand how to find the time it takes to stop the thing
also, when your talking about a ball bouncing up and hitting a spring, the compression would not be the same as if it had happened on a horizontal surface, because gravity would also be doing work on the ball too, right?
if the object comes and hits the spring again(after being pulled down by gravity) and hits the spring out of phase, will you still need to take the work done by the spring? also, what if it- let's take this with a spring vibrating up and down now- hits the spring above the equillibrium point, where the force on the end of the spring is downwards? how does the object behave then?
YES, of course the compression will be diffrent because of the gravity's force...
In this situation you don't only have kinetic energy but you have the gravity potential energy as well. The equation will be this then .5kx^2=.5mV2+mgh (in the vertical bouncing)...
but if it ball is traveling a horizontal distance you don't have gravity's potential energy hence the x would be less...
I hope I realized your question correctly..
[tex]F=-kx(t)=m\frac{d^2x(t)}{dt^2}[/tex] (Newtons second law F=ma)
This is a differential equation with the general solution:
[tex]x(t)=Asin(\omega t)+Bcos(\omega t)[/tex]
With [itex]\omega=\sqrt{k/m}[/tex]. Applying initial conditions; say x(t=0)=0<br /> [tex]x(t)=Asin(\omega t)[/tex]<br /> <br /> The spring is totally compressed when:<br /> [tex]sin(\omega t)=1[/tex] so [tex]t=\frac{\pi}{2 \omega}=\frac{\pi}{2} \sqrt{m/k}[/tex]<br /> <br /> And thus depends only on the mass of the object and the spring constant and not on the initial velocity of the object![/itex]
  • · Replies 24 ·
  • · Replies 19 ·
  • · Replies 17 ·
