What is the final temperature of a mixture of steam and ice?
The final temperature of a mixture of 10.0g of steam at 100°C and 50g of ice at 0°C is calculated to be 33.33°C. This calculation utilizes the principle of conservation of energy, equating the heat lost by the steam to the heat gained by the ice. The specific heat capacities used are 4.18 J/g°C for water and 2.09 J/g°C for ice. It is crucial to consider latent heat during phase changes, and the calculation assumes no heat loss to the surroundings and complete condensation of steam.
  • Understanding of latent heat of fusion and vaporization
  • Knowledge of specific heat capacities of water and ice
  • Familiarity with the conservation of energy principle
  • Ability to solve algebraic equations
  • Research the latent heat of fusion and vaporization values for water
  • Learn how to apply the conservation of energy in thermodynamic problems
  • Explore the effects of heat loss in real-world thermal systems
  • Study phase changes and their impact on temperature calculations
Students in physics or chemistry, educators teaching thermodynamics, and anyone interested in understanding heat transfer in phase changes.
mickeychief
I keep getting 16 degrees for the temp.. This isn't the right answer... Can anyone help??
Steam at 100 degrees C is added to ice at 0 degrees C. The mass of the steam is 10.0g and the mass of the ice is 50g. What is the final temperature of the mixture.
Remember that upon melting or condensing there is a latent heat that must be considered. So for example, when ice melts and is heated to say 25 C, the total heat transferred to the ice is given by the latent heat of fustion (the heat needed to melt solid ice at 0 C to liquid water at 0 C) and the heat needed to heat water to 25 C. A similar situation occurs with the steam. Remember though, the latent heats of fusion and vaporization are not the same. Just look the values up online.
The final temperature of the mixture of steam and ice can be calculated using the principle of conservation of energy. The heat lost by the steam will be equal to the heat gained by the ice, resulting in thermal equilibrium.
To solve for the final temperature, we will use the equation:
Qlost = Qgained
Where Qlost is the heat lost by the steam and Qgained is the heat gained by the ice.
The heat lost by the steam can be calculated using the equation:
Qlost = m x c x ΔT
Where m is the mass of the steam, c is the specific heat capacity of water (4.18 J/g°C), and ΔT is the change in temperature.
Substituting the given values, we get:
Qlost = 10.0g x 4.18 J/g°C x (100°C - Tf)
Where Tf is the final temperature of the mixture.
The heat gained by the ice can be calculated using the equation:
Qgained = m x c x ΔT
Where m is the mass of the ice, c is the specific heat capacity of ice (2.09 J/g°C), and ΔT is the change in temperature.
Qgained = 50g x 2.09 J/g°C x (Tf - 0°C)
Now, equating Qlost and Qgained, we get:
10.0g x 4.18 J/g°C x (100°C - Tf) = 50g x 2.09 J/g°C x (Tf - 0°C)
Solving for Tf, we get:
Tf = 33.33°C
Therefore, the final temperature of the mixture of steam and ice is 33.33°C.
It is important to note that this calculation assumes that there is no heat loss to the surroundings and that the steam condenses completely into liquid water. In reality, some heat may be lost to the surroundings and not all of the steam may condense, resulting in a slightly lower final temperature.
