| New Reply |
Pitching moment and lift coefficient |
Share Thread |
| Mar29-11, 04:36 PM | #1 |
Consider a proposed airplane design shape in a wind tunnel. The forces and moments are measured at the proposed center of gravity location. At zero angle of attack, pitching moment is zero and lift is 10N. At 5 degrees angle of attack, pitching moment is -5Nm and lift is 60N. The chord of the wing is 1 meter.
(a) What is dM/dL (sensitivity of pitching moment to lift coefficient)? (b) What is dCm/dCL (sensitivity of pitching moment coefficient to lift coefficient)? (c) Is this design longitudinally statically stable? I have no idea how to do this. The formula for pitching moment coefficient is Cm=Cmwing+(h-hwing)Clwing-(Vh)(Cltail). I honestly don't think this equation applies in this problem, because there is no h, tail dimensions...etc. So I guess I'm supposed to figure out the pitching moment from the given data. But I need the line equation to do that? How do I find that? Am I even going on the right track? Thanks a lot |
| Mar30-11, 08:55 AM | #2 |
You're forgetting that [tex]C_M = \frac{M}{qS}[/tex] and [tex]C_L = \frac{L}{qS}[/tex]
| Mar30-11, 09:22 AM | #3 |
| Mar30-11, 10:33 AM | #4 |
Ah ha, so I plug it in and that's the answer right? Thanks a lot.
| New Reply |
Similar discussions for: Pitching moment and lift coefficient
| Coefficient of lift formula | General Physics | 7 | ||
| Lift and Drag coefficient equation in terms of pressure | Mechanical Engineering | 3 | ||
| the question about pitching moment: | Advanced Physics Homework | 0 | ||
| Zero Mach number lift coefficient | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Aerodynamics: Wing Pitching Moment | Aerospace Engineering | 4 | ||
