New Reply
Calculating modulus of elasticity?
Share Thread Thread Tools
Mar29-11, 06:12 PM   #1
I'm trying to figure out how to calculate the modulus of elasticity for a board clamped to a surface plate at one end and free-floating on the other. I've measured the deflection with a 1k weight at the free end of the board. So I've got that data as well as the dimensions of the free-hanging portion of the board.
I've done this test with numerous boards of different thicknesses and dimensions and want to compare them in terms of stiffness.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Mar29-11, 06:48 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi tobyrzepka, welcome to PF. Try a search for "beam bending equations" to find the deflection vs. Young's modulus for a number of different boundary conditions. For the case of a cantilevered beam (clamped at one end, transverse load on the other), the deflection is [itex]\delta=PL^3/3EI[/itex], where [itex]I=wt^3/12[/itex] is the second moment of area. Does this answer your question?
Apr3-11, 07:52 AM   #3
Like Mapes stated correctly, δ=F*L^3 / 3E*I
Since you measured deflection you can solve as E (elasticity modulus) and you'll have it.
E=I*F*L^3 / 3δ
F = Force applied (1kg as you mentioned)
L = Length (Length of each board)
E = Elasticity modulus (You will do the math)
I = Inertia moment (b*h^3)/12 where h=width of board and h=height (thickness)
δ= Deflection (As you measured)
I hope that helped
Jul6-11, 04:03 PM   #4
I assume you meant b = width of the board, and h = height... is that right?
Quote by polymerou View Post
E=I*F*L^3 / 3δ
I hope that helped
Jul26-11, 12:20 PM   #5
b=width, h=depth/height
for a rectangular section I =(b.h^3)/12
New Reply
Thread Tools
Similar Threads for: Calculating modulus of elasticity?
Thread Forum Replies
need help on modulus of elasticity Classical Physics 0
Modulus of Elasticity Engineering, Comp Sci, & Technology Homework 4
modulus of elasticity Engineering, Comp Sci, & Technology Homework 1
Modulus of Elasticity General Engineering 1
Modulus of elasticity Introductory Physics Homework 2
